- Yj Soft Top
- good running 4.0
- clean fullsize bronco tailgate. any year.
- Wtb: Hard To Tj
- ///// TRADE..TRADE.. TRADE \\\\\ for 33`s with tread !!
- 4.10 gears for a d60 rear
- TJ 4" Pitman Arm Drop
- WTB: 37-38.5 inch tires
- 350 swap engine mounts
- 302 headers
- 94 Cherokee Front Bumper
- auto trans, 97 Caravan
- YJ Carpet
- pressure washer
- xj FLOOR replacements
- 16x10 - 5 on 4.5
- 16x10 or 16x8... 6 lug wheels
- wanted 3" lift coil springs for xj
- toolbox
- grand cherokee fog lights
- yj rear belt
- 68-72 corvette
- Old soft tops...torn, holes OK
- WTBorrow: Space heater
- Need chevy parts
- wanted: np 205 t-case
- alternator Bracket
- amc v8 timing cover
- Ford 8.8
- Scout D44
- WTB 34x9.50x15 Pizza cutters
- Power Wheels Jeep
- BB Lift
- stock looking wheels/tires for cj3b
- stock flatty seats
- Shipping: Idaho to Michigan
- Driver Doors from a 97 down 4 door XJ
- Power wheels or other ride on toys for project
- anyone know
- tail light for 93 xj pass. side
- Please delete
- WTB: 2.5 or 4.0 w Tranny, T case etc
- wtt stuff
- tonneau cover
- 39.5-44" tires on 16.5" rims
- Proportioning Valve for '73 CJ5 Drum Brakes
- wanted, tj bb,stock shocks, and 4:10-4:11 gears
- yj windshield frame & glass
- 15x12 wheels 5 on 5 1/2
- Manifold Adapter Plate for Weber
- 4'' Ford TTB lift coils & shocks
- *Found one*OEM T176 to Dana 300 adapter
- samurai t case
- Xj Seat Belts
- parts for 1973 CJ5 needed
- Intellivision
- '96 ranger tailgate
- 31/10.5 R15 tires
- complete pulleys for 304
- 35s needed
- Look @ starter wiring --Yj 258
- 33/12.5 r 15
- got to go
- 56" chevy springs
- Cancel
- 2000 chevy classic 1 ton springs
- Wanted - CJ windshield hinges - possible trade
- fuel cell
- Early bronco body
- tj or yj, blwo up or wrecked.
- TTB d28 d35 radius arms
- wide jeep rims
- i wanna bronco II
- rear leaf spring
- cheap rims for a blazer
- D30 Carrier for 4.10s - FOUND
- Bestop supertop hardware *FOUND*
- 92-96 Ford 40/20/20 split bench seat
- Need CJ5 soft top
- 72 Chevy parts
- t case yoke
- 16x8 or 10s
- Custom Exhaust for 2000 XJ
- need a exhaust manifold 4.0
- Dana44 Yoke
- Samurai rear axle comp;ete. Thx.
- Sye And 36 In Tires
- Space
- Trailer tires
- Looking for a Ford 9 inch R&P. May Also need a D44 Carrier and R&P
- one stock 91 chevy rim.
- Wanted 4-17" F150 4x4 tires, 50%+ tread?
- rear view mirror for a yj
- 17" dodge ram "off-road" wheels
- ranger c5 bellhousing
- Need a soft top for a '81 CJ5.
- 90'S jeep wanted
- 16x8 or 10s 8 lug
- Hard Upper Doors
- Nv3500 Tranny
- stock tires
- 35' tires
- Wanted ASAP 97+ XJ Drivers side window switch
- tires and rims
- WTB Ford Ranger 8.8 rear
- Plasma Cutter
- Heater Control Unit '95 Chevy/GMC
- 9.5" 14 bolt, 6 lug
- lift kit
- 2 34-9.50-15 tsl
- Yj Tub Black
- ford 208 or 205
- borg warner 1354 t-case
- dana 18
- 79 ford door
- 2001-2004 Jeep Grand Cherokee WJ
- XJ fuel filler neck
- 3-4 inch lift for tj
- wanted: 95 or newer truck
- T-Case Slip Yoke
- trans for 1994 blazer
- Wanted: Cheap steel wheels
- 97 ford rim
- power stroke
- 700r4 transmission for camaro
- HELP! I need a new motor
- 42 Re Transmission
- Newer 33s
- axles
- yj parts needed
- front waggy leaf spring
- turbine style dodge wheels
- Need XJ Air Box
- Need Xj Air Box
- 56" 1310 driveshaft....
- Rocks
- Stock 4cyl. Speedo gear 41 tooth NP231
- 205 or 208 T case
- WANTED: Holley 4150 Secondary Metering Block
- chevy dana 44 or 10 bolt with 410s
- 89 jeep cherokee 2 door drive side door glass
- Stock Dodge Dakota Sport Suspension
- American Racing Baja wheel 15x10
- Stock TJ Flares
- lift kit for a 94 bronco 4 to 6 inchs.
- Non Tilt Driver Seat Riser
- AMC 20 yoke for a cj-7
- Lift for a Jeepster
- Fiberglass front fenders&hood,3:73 geared front dana 30
- wtb 35" tires
- Ford bed
- 77 Ford F150 D44
- YJ Fender wheel wells, Any condition
- 6.2 diesel
- Wanted: YJ stock springs
- Dana 30 HP + Ford 9" 4.10's
- external auto trans cooler
- TJ Dana 30
- WTB Full Size Blazer or similar
- 2003? ZR2 fender flares
- Some kind of flex joint NON hiem
- stuff for my project
- WTB:5.5+ coils
- 302 ho 4bbl intake
- wanted dodge 318 magnum.
- cheap gas saver perfer under $3000
- Cylinder for hydro Assist
- ram d44
- 3-3.5 inch coils
- 96-99 5.7L Vortec
- Got them! driver fender for cj7 - steel
- got them!!! lift leaf springs for cj7
- WTB 98 Grand Cherokee Limited 5.9
- 78-79 f-250 dana 44 3.73 gears
- T-5 trans
- 8274
- YJ soft uppers and soft lowers or soft uppers and hard lowers
- 31-32" tires/rims (5x4.5), yj lift springs
- (1) 31x10.5x15 Tire for spare near Lansing
- Chevy rear leaf springs 88-98
- D35c shafts
- Wanted: TJ Rubicon Tires and Wheels
- Goodyear 31x15.5x15 Terra tires
- please delete, found a motor, thanks brian
- hi i'm looking for a set of 4 mud and snow tires 305-70-16
- yj frame and tub
- asap leaf spring pearches
- Need at least 1 Goodyear GSA 30" R15
- Firewood wanted
- 16" Rims 5 lug For a GM/Chevy Truck!
- xj cherokee
- 17" dodge rims
- YJ windshield frame
- Radiator for CJ Chevy conversion *FOUND*
- XJ Front Swaybar - GOT IT
- AMC inspection cover
- 15x10" with 5x5.5 lug
- xj parts
- Tube fenders for YJ
- Free? leafs
- Wanted 5x5.5 rims for rollers
- winter beater
- 600 cfm edelbrock
- WTB Hard Top for a Samurai
- WTB Spare 31x10.5x15 BFG or similiar
- looking for 2 inch shackles for a xj
- horizontal shaft engine wanted
- ramcharger
- wanted plow or blade
- Jeep Cover
- sets of fullsize chevy axles
- torch tanks
- Silding windows for blazer
- yj, xj or waggy leafs
- 4x4 crew cab dodge
- wtb: anything better than a d35 with 3.73's
- 8 ft truck cap topper
- Seats for YJ
- need a running 460
- 5 on 4.5 rim wider the better Need a spare
- 3 or 5 point Harness's
- YJ doors
- cross member/skidplate yj
- some what vintage
- YJ stock steering
- dana 300??
- 2 35x12.5x15 Mud Kings
- XJ Stock Air Intake Parts
- Coil over shocks or Remote Gas Shocks
- Winter Tires (31",32" or 33") 15" rim
- XJ Rear Wiper Arm
- 4x4 $1000 and under
- need ASAP today
- Gas Tank Skid
- Need 1 Chevy truck 6 lug rim for trailer spare
- tj rear axle
- Need Chevy Leafs
- YJ Instrument cluster
- FSJ Gas Tank Skid
- Spindles
- 97-01 XJ Right Taillight
- nissan hardbody doors
- 96 and newer 4.0L Throttle body.
- black steelies
- SBC YJ Swap Parts
- xj or dodge 4x4 under 1000
- 96 GM Tailgate Hinges
- Desk
- 36" - 38" tires / 10" wide 5x5.5 bp rims
- 1994 Grand Cherokee Hatch Lifters
