Wanted [Archive] - Page 3 - Great Lakes 4x4
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51
  1. 4.0 or 5.0 drivetrain for my TJ
  2. Tires
  3. black plastic grille..other '94 crap
  4. stock TJ front swaybar links
  5. chevy 4.3 V6
  6. Cj or YJ windsheild
  7. Place to stay in Indiana
  8. Does any one have any coils or airbags they do not want or need.
  9. Drywaller
  10. Winch plate
  11. Hi-Lift 4XRAC
  12. *** Cj Tailgate HARDWARE ***
  13. 4-6inch Shocks for an XJ
  14. Dana 44 parts
  15. help
  16. Reverse cut 4.10 60 gears
  17. Roomate in Mount pleasant
  18. hand held gps finder
  19. pontoon paddle boat
  20. Stock ZJ front springs
  21. Free Power wheels (Bigger one)
  22. solenoid valves...
  23. 35-37" tire for spare
  24. WANTED Transfer case NP 231 working or not! Need case or GOOD HD CASE COMPLETE
  25. 90ish chevy 350
  26. 88 brono tranny
  27. dana300
  28. Anvil Wanted
  29. yj tailgate hinges
  30. Tow Rig 3/4 ton or bigger
  31. YJ Powersteering BOX!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  32. 241c
  33. Scout D44 stubby shafts and short and long side if you have?
  34. WTB 5x5.5 wheels!
  35. 2.5 motor
  36. Sex
  37. *sigh* chevy 350
  38. Xj front d-shaft
  39. Soft top parts for tj rollbar brackets/rear window channel
  40. WANTED NP 231 for jeep Wrangler good or bad and sye wanted
  41. h2 rims
  42. front drive shaft for a 88yj
  43. TJ Dana 30
  44. Wtb 31 Inch Tires ( i have CASH )
  45. Flattie Parts, BOP Bellhousing
  46. TJ backseat locking mechanism
  47. 125 or higher dirt bike
  48. 16.5x14 wheels
  49. xj fender flare
  50. House with 3+ car garage or pole barn
  51. Black Steelies 15X8
  52. Tires: 265/75R16, 285/75R16, etc something for a 3/4 ton..
  53. Stock front Coil spring
  54. CJ or YJ windsheild
  55. wanted early bronco
  56. In the Market for a TJ
  57. '83 cj's
  58. toyota t-case
  59. 8 LUG WHEELS W/ OR W/OUT TIRES lookin for under $100
  60. XJ Wheels 15x8's
  61. Swingout carrier
  62. Dana 35 4.10/4.11 ring & pinion
  63. RE 1.5" SOA springs (2)
  64. Grille
  65. Full size truck tool box
  66. Jeep T176 trans needed........
  67. DJ and Photographer in Sag/BC/Midland Area
  68. FSJ plow setup (w/electric pump)
  69. dropped pitman arm
  70. 23 spline NP231 t-case
  71. tf727 3spd auto
  72. 04 WJ grand Cherokee Grille assembly and DS headlight
  73. dana 20
  74. ZJ sheetmetal & rear wiper asm
  75. yj body parts
  76. T176 Inspection Cover
  77. 33" BF Goodrich At KO
  78. 35-50 hp outboard
  79. 33 X 12.50 BFG Muds or Mt/R's
  80. ford pickup bed
  81. Ford Ranger with stick
  82. Looking for a 15x10 5-4.5 Spare Wheel
  83. needed for 93 xj right s ide
  84. TJ parts
  85. Tj
  86. Automatic......Got one!!
  87. 38-40
  88. dump truck & bobcat
  89. Two WD 700R4
  90. 16s
  91. ramcharger or trail duster 4x4 ohio
  92. YJ pitman arm - manual steering
  93. XJ and/or Old Beater Pickup
  94. Yota Tires Rims
  95. 4.10 gears
  96. 16" wheels for xj
  97. Good Running 2.5
  98. 37" spare tire
  99. wheel spacers
  100. Need 4.0 for a 94 Yj with a AX-15 (manual trany)
  101. 5 1/4 speaker grills
  102. Nv3550
  103. YJ Parts Needed!
  104. Ford 9"
  105. wanted chevy truck bucket seats
  106. electric fans for xj
  107. Truck Cap/Topper for a 8 ft Dodge Ram bed
  108. 2 285x75 R16 in decent shape and decently priced...
  109. xj 4.5-5inch lift
  110. Control Arms TJ
  111. Wagoneer D44 Shaft
  112. D30 passanger axle shaft
  113. ARB compressor pump..maybe a Ruby one even
  114. SYE & CV Driveshaft
  115. NEED XJ shifter and Linkage for AW4 and a few other things
  116. two tires wanted 33x14.5x15
  117. Adj Trac Bar TJ
  118. D44 dr side rear shaft
  119. looking for tires
  120. 33x12.5 mudrover!!!
  121. 01 XJ Driveshaft
  122. looking for engine
  123. Stock Tires
  124. WTB Dana 60 front 4.56 n up carrior
  125. TJ Soft top windows, Spice
  126. TJ Tan Half door interior panel.
  127. looking for 318 and trans or either one
  128. i need .............
  129. Corp 14 bolt locker and or 4.88 gears
  130. one 33x12.5x15 for spare
  131. YJ tailgate
  132. Dana 30 U-Joint Yoke
  133. Not a joke but need a d 35 rear
  134. Looking for a wine rack...
  135. TJ flares
  136. 46re tranny For Dodge Ram
  137. Dana 44 stuff
  138. jeep 904 auto trans
  139. Good Hvlp Wanted
  140. Yj Tub
  141. Nextel v180 or i930
  142. 4.56 or 4.10's
  143. wanted 33inch tires
  144. XJ Headlight bezel, lens, lower bumper plastic.
  145. yj or cj tub
  146. Powerwheels
  147. TJ 1" BL and MML
  148. black interior parts for yj
  149. 03-04 WJ headlight
  150. wtb: Auto transmission for a 97 TJ with a 2.5L
  151. where can i buy 2x4x.250 wall tube on saterday
  152. 97-01 XJ driver side tail light
  153. Cj Grill
  154. Pop-up camper
  155. Need a floor shifter/driveshafts
  156. Tracker or Sidekick.
  157. discos
  158. Kayak
  159. d 35 carrier
  160. never mind *delete*
  161. Need a few things for a cj
  162. Jet Ski Trailer
  163. 2 door seats, trim
  164. Dodge Axle
  165. nv3550 shifter
  166. wtb: 2" hitch for 2000 model s-10
  167. WTB NV3550 complete
  168. 2000+ Tj 4.0l
  169. CJ Tailgate HINGES
  170. 76-83 CJ Windshield Glass
  171. metal shavings from lathe,drill press
  172. yj brake booster and pedal
  173. DVD's
  174. Dodge Ram Knuckle
  175. in need of 38's
  176. TJ Rear Bumper
  177. XJ upper control arms- fixed or adjustable
  178. Crib...
  179. Rear discs
  180. Place to live - Ann Arbor
  181. WJ knuckles
  182. Drivers Drop Dana 44 Housing
  183. Right-side Axle Shaft
  184. zj lift and trans
  185. big block chevy running, rebuilt?
  186. chevy springs
  187. toyota parts
  188. dropped drag link
  189. Truck
  190. WTB: wheels 15x8 with 5x4.5 bolt patern and 3.5 to 4.5 b/s
  191. electric sander/buffer
  192. Need 4.0L 242 I-6 for 1992 Cherokee Laredo
  193. HiLift 4XRAC
  194. Wanted: Free Tj flares
  195. Tj Hitch!
  196. Headers or exhaust manifoild
  197. 78-79 ford 3/4 ton axles
  198. TH350 or TH400 for SBC
  199. WTB 15" 8 lug rims
  200. Need to borrow a cherry picker Clarkston area
  201. gas tanks
  202. Axles with 4.88s (possibly 4.10s)
  203. ...........
  204. auto floor shifter
  205. good set of small block chevy heads.
  206. CJ-7 Gas Tank
  207. seadoo engine
  208. Oxy/Acetylene Cutting Torch
  209. 265/70-R17 or 275/70-R17 tires...
  210. 31" BFG mt's
  211. Cylinder heads for 69 Buick 350
  212. 16" 8-lug wheels
  213. sway bar links
  214. XJ springs
  215. NEEDED!! d 35 carrier
  216. Front Dana 30 for XJ
  217. Dana 44 Parts
  218. Tj Hitch
  219. 350tran and a tcase
  220. gas tank for jeep
  221. Black 15x10 rims for the CJ7
  222. Wanted 90's XJ
  223. 1 YJ hood hinge
  224. TJ Stock CD player
  225. Dana 30 w 4.10s or better yet 4.88s
  226. Idler pulley
  227. Please delete...
  228. tj adjustable track bar
  229. 38.5/12.5 Or 14.50/15
  230. H1 wheels
  231. sye for np231
  232. windshield frame
  233. sport bike, crotch rocket...
  234. Iron Duke 4-cyl. inspection plate(s)
  235. Need New TV
  236. dana 20
  237. a/c clutch
  238. xj computer 91-96
  239. YJ Front Driveshaft
  240. CJ anti-sway bar
  241. Clean YJ/CJ Door hard doors/shells
  242. 350 SBC and 350 turbo trans.
  243. tailgate bar clips tj or yj
  244. 35x12.50x15 tires
  245. 33x12.5x15 swamper boggers
  246. Family style Roll bar for a YJ
  247. Need a Power wheel for a kid. In good shape
  248. Fender
  249. np 231 parts
  250. WTB: Ford big block bellhouseing
