- wtb set of 38's
- power window motor
- Contact info where I can get a custom speedo cable made?
- 1995-02 mustang
- Tickets for brad paisley
- Durango Steering Box
- Walk behind snowblower
- tj seat brackets
- 3.73 and up carries for d30
- 3.7 liter
- WANTED - 5 33x12.50x15 (TIRES AND WHEELS)
- chrysler wheels for and 01 sebring
- Need a fuel pump!!
- 8.8 for 97 F150
- someone to bend some tubes
- S-10 Leaf packs.
- tf-727 valve body...
- F150 8.8 drum brake parts
- 15x10 5x4.5 3.75 BS
- Driver's seat 05 Ford Focus
- Building Front Dana 44 For YJ
- roofing contractor
- ps pump brackets for 70's 258
- gears for my zj dana 30 and 35
- slide in pickup camper
- large trailer to rent
- a borg warner T5 transmission
- 4.3 vortec w/ low miles
- 318 for my 99 dodge
- WTB: Snowmobile
- 16" rims 5x4.5
- solid d30 diff cover
- need a starter for an 89 XJ."got one" plz DELETE
- YJ heater control cable. The short one from heater selector to floor (2'-3' long)
- Wanted: Manx Style VW Buggy
- TJ Half Doors *Black* or any color
- Wanted: 33" tires or bigger
- adapter
- Gears and Axles for a Ford
- Fullsize Jimmy Parts
- dana 44 4.88s.
- ford 4.0 v6 heads
- want 33 to 35 inch tires 16 inch rims
- Powerstroke Crew Cab Manual Trans Truck
- pass side tail light for a 95 xj
- wanted
- flat top knuckle
- Anyone Have a Plow For a Ranger/Explorer?
- found plz delete
- ZJ rear LCAs for a 3" lift
- Back glass for yota p/u
- 97-03 f-150 8ft cap
- Beer Bottle Caps
- ranger frame
- LOOKING FOR 2 31 inch tires
- 3.0 for a ranger
- Marine Exhaust manifolds
- 88-95 toyota drives side door
- Wanted 4 suspension lift YJ
- starter for yj w/ 258 engine
- disco's
- Intake Manifold
- 98 TJ adjustable trackbar
- chevy 6 lug 10 bolt axle
- WTB Ruger 10/22 or 22 Mag
- stock rubi shocks
- ZJ front trac bar
- tires... 285/75/16
- s-10 grille and driver side head light bezel
- Long Shot - Transmission for Lumina Van
- *FOUND* Jeep YJ D35 rear axle - 3.07
- 2'' tow hook/d-ring
- Rear seat for an 03 Wrangler
- 2005 Top Truck Challenge dvd
- lookin for 4x4 for under 1800
- stock TJ skidplate
- xj leaf springs
- Snowmobile trailer +++ FOUND +++
- tj front drive shaft
- Dana 60 Diff Cover
- 6' plow blade
- no more
- I Want A New Car/truck/suv
- project items needed
- wtb a 97 jeep grand cherokee motor trans tc
- Need 4.88 Gears For A Dana 30!!!! Asap
- 4x4 Quad for under $2500
- 4.0 oil pan Got one thanks
- gears for a dana 35
- WTB front and rear hitch 2" for a 98 XJ
- Ford D44 flattop knuckle
- YJ frame, tub, grille, hood, and fenders
- 35 inch mt tire
- Looking for hydraulic clutch slave and clyinder
- 14 bolt cover
- WTB Winch
- wtb rifles and reloading equipment
- WTB Radiator for 96 Jeep Grand Cherokee
- 91 Yj Radiator 4.0 Auto
- wtb lift leaf springs for 1989 f-350
- TJ frame
- 96 Grand Cherokee ECM
- plow vehicle or mower/snowblower combo
- Front XJ lift shocks
- TJ 1/2 Door Hardware
- 1990 to 1994 YJ with good frame and tub.
- No longer needed/ found. 97-02 tj or xj leather wrapped steering wheel
- looking for set of 38'' or 40'' tires
- wanted: help building my ZJ
- Looking for Adapter
- Ford Bronco
- 15 x 8 Soft 8's w/ 4.75 BS 5 on 4.5
- wtb 33's and tummy tuck
- Shuffleboard
- explorer/ranger d35 axle shaft
- front and rear dana 44's
- Tires 245/75/15 or 30's
- Wanted 5.7L hemi drop out
- 2 stock F150 rims
- Dana 44 5.13s AND a front quick lock
- wanted to trade or buy tires for tires
- wanted 8.8
- nerf bars
- lowering kit
- Aluminum SBC whole or bock
- 99+ chevy tracker tub or whole truck
- HP dana 60 center section
- scout dana 44
- looking for leaf springs
- Hubcaps
- 70's/80's 2 stroke dirtbike motor...
- Parts transport: Allegan, MI to southeast MI
- 215-85-16 tires or close
- 33 12.50 15 mt/r
- CJ door parts
- Soft top quick connects
- XJ Tow Hooks With Brackets
- 258 rods and crank
- 87-95 yj tailgate
- 35x12.5r15 mt radials
- Multiple Body Parts Needed for 1997 Wrangler
- need a Chevy tranny & case for a YJ
- Front hub bearing assemblies wanted
- WTB 92-96 Chevy or GMC Suburban 4X4
- d44 4.56 or 4.88 gears
- tj 4.0 radiator
- tj windshield frame
- ECM TJ computer
- XJ rear leaf springs "Found"
- CJ deck/bed/tonneau cover.
- U-joint steering shaft or two
- Wanted - set of 30x9.5 or 31x10.5x15 tires
- Need a wheel
- 35-12.50-15.
- electric trolling motor, or small outboard
- D44 short side shaft
- 16x10 rim - 5 on 5.5
- Tires 265/75/16
- Rocks and busted up concrete
- 245/65r/17 New tires
- 4.0 block
- Main Drive Gear for a T-14
- 82 CJ7 air box
- someone to set timing chain on 88 comanche
- Jeep 'Gambler' Wheel
- Stock Chevy leaf spring block
- Hummer Beadlocks Wanted H1
- parts wanted/needed
- 3500 # trailer axle
- Brush Guard
- Rims
- TJ rear sway bar
- 38-40 Tires... not 16.5" wheel
- 4-11 gears
- WTB: Metal Gear Solid (1&3)
- Want To Buy
- enclosed sled trailer
- adapter
- Cj7 tub
- Looking for Rollback or Flatbed truck
- 33 " spare
- amc v8 timing chain cover.
- 31 at's
- 4.10 gears
- 285/75/16
- WTB good set of 33 or 35in tires. Must fit 16in rim.
- 8.25 4.56 gears
- rims / tires
- stock s-series overload leafs
- Small block V8
- Land Rover Discovery
- s 10 or similar springs
- 3" shocks for an xj
- TJ/XJ/Dakota/Durango steering box
- A drop pitman arm for an XJ/MJ
- Front lift springs - to net 3-4" on xj
- Jeep ZJ front driveshaft
- Grand Cherokee Glove box parts
- xj wheels and tires tj
- 84-96 xj LF door glass 4door "found/bought
- 4:10 9 inch third member
- 31" MT's
- Need 79 Chevy Grill mounts
- flowmaster 40 series
- radio
- Ford Ranger rims
- 31 Spline Ford 9"
- Wanted; Ford Ranger Center Caps.
- Complete Motor for sale 4.2L block w/ 4.o head
- Ford Focus Seat & Dodge Ram Doors
- Passenger side inner + outer axle shaft for 86 G. Wagoneer
- BIg Red ATC
- amc tranny to gm motor adapter
- Ok, THIS IS NOT FOR ME. Hanna montana tickets.
- gears
- Hp30 Non disco XJ/TJ ******FOUND********
- 35-37" MT 16" wheel
- Radiator YJ
- D44 Front
- heim joints or johny joints
- 3 in to 4 in lift for yj wrangler
- old boat motor
- TJ soft top brackets
- Radiator For Cj 7 Inline 6
- Top and Doors for '89 YJ Hardtop preferred
- Samurai Low Tcase Gears and Geared Third members.
- Light home electrical work
- WTB Ford F-150 tires....32x11.50 R15...
- cheap winter beater
- Honda Big Red or 200X 3 wheeler
- TJ half door sliders/ used tj soft top (black)
- Rear Sway Bar Link Poly Bushings
- 94 yj frame rail
- cj seats
- jeep 258 4 bbl intake manifold
- 40"+ tires for 16.5" rim
- need Dana 35 axle shaft!!
- 32x11.5x15 BFG A/T for spare
- Wanted yj tierod & drag link
- 2 - stock TJ/XJ/ZJ drag links
- wanted: YJ/TJ front sealed wheel bearing 1987to2006
- 1986 3/4 ton chevy truck
- NEED! Grand Cherokee limited 247 t-case
- 16.5" 6x5.5 RIMS !
- WTB (2) 5 on 4.5 wheels 8"-10" wide
- tj power distribution harness
- WTB Ranger
- Black 16x8s or 16x10 8 lug
- WTB:Chrysler 9.25, 9 1/4 3.92 or 4.10s
- YJ, XJ with bad motor 4.0.
