Wanted [Archive] - Page 26 - Great Lakes 4x4. The largest offroad forum in the Midwest
  1. need axle for 2000 XJ
  2. 1- Wheel,15x8 or 10, 5 on 4.5 for spare
  3. tires 305/70/16 or 285/75/16
  4. 97-? Dodge ram clean doors
  5. tonneau cover or topper for 92 s-10 w/ shortbox
  6. Wtb 4l80e 4x4 Tranny & T-case
  7. NP231 output shaft
  8. 33inch swamper
  9. place to duck/goose hunt near GR
  10. Dana 300 parts.
  11. 16 inch tires
  12. XJ Springs
  13. Looking For Nextel Phone!!!!
  14. cheap broken 2-10gallon electric air compressor
  15. 31 inch tires
  16. 94 grandv8 trans 46rh
  17. wanted 410 gears and one piece axle dana 30
  18. YJ front seat belt receivers
  19. Looking for 1 Egle 15X10 alloy
  20. TRADE???? my 35" BFG AT'a for your 31" Somethings?
  21. Wanted 16" 8 Bolt Rims!!!
  22. TRADE??? My 37's for your 35's
  23. zj coils, shocks, and dana 30/35 gears
  24. WTB.....32's.......to fit my 15in rims
  25. 33" tires
  26. wtb- tracker shifter assembly
  27. AL4D 4x4 Ranger Trans
  28. Tube Bends -
  29. s10 rear springs
  30. Sheet Metal press brake
  31. 32" Muds, Alum 5x5.5 wheels
  32. 8" lift springs
  33. Plain White CJ Wheels
  34. 2 5x4.5 wheels - NVM
  35. Part time Job
  36. Frame or rolling chassis CJ5 1972 or newer wanted
  37. A couple yj things needed
  38. bellehousing
  39. 94YJ frame needed
  40. Looking for YJ soft top w/hardware
  41. YJ shifter Boots
  42. 30X9.5XR15 Goodyear MTR
  43. 2 31X10.5 BFG Mts
  44. Looking For Some Cheap Chevy's
  45. sm420 transmission
  46. xj window seal, window reg, locks
  47. dodge ram bug shield
  48. Core support for 81-87 Chevy pickup
  49. trailer hitch
  50. Rear axle for a 03 dodge 4x4, 3:92 ratio
  51. Snowmoblie with a blown motor.
  52. need 8 bolt rims with GOOD tires
  53. 79 ford 2wd 4 spd od trans
  54. yj door skins
  55. 1/2 Ton Chevy Axle Carrier
  56. CHEAP!!!! 4cyl FWD cars wanted for enduro races.
  57. Need a running 4cylinder.
  58. digital video camera
  59. Tube Bender
  60. NEED second gen ram stuff
  61. S-10 leaf springs for XJ
  62. 98 Dakota Bed Cover
  63. Dana 35 axle housing or complete assy.
  64. WTB 86 chevy lift kit and tires
  65. dodge 3/4 ton or 1 ton non dually axles!
  66. 10 Bolt Axle with 3.73's
  67. TH350 or TH400
  68. Wanted Ruger 10/22
  69. wtb 700r4 for a 96 tahoe 4x4 5.7?
  70. drivers side spring bucket for my 1990 ranger
  71. anybody have a mangled trailer???
  72. Jeep YJ Wanted
  73. WTB tonneau cover for 1997 Ford F250 SD short box
  74. WTB ford f150 8.8 rear end with 4.10 gears
  75. Plastic bedliner for truck
  76. 36-12.50/15 Spare tire needed
  77. WTT: Durango Radial XTR 305
  78. 36 or 37x16 tires
  79. newbie looking for a part
  80. 285/75/16 Spare Tire Needed
  81. 4.0 for a 99 XJ
  82. GM 2.2 FWD Engine
  83. 8hp honda
  84. xj parts
  85. .22 rifle, pump or level action
  86. dodge ramcharger or ext cab 4x4
  87. 16.5 5x5 1/2 bolt pattern wheels
  88. Looking for 33-12.50-15
  89. dana 30 ring n pinions
  90. 5Kwatt generator head
  91. A Goodyear MT/R 245/65/16
  92. 31x10.50x15 dunlop mud rover or similiar
  93. WTB: 265's for my truck
  94. 350 Parts!!!!!!.
  95. Yj Bellhousing
  96. WTB 16.5 5lug 5.5 wheels
  97. WTB: Hitch
  98. cowl hood and fascia for camaro
  99. lookin for 488 gear and high steer arms for a dana 60
  100. 275/65/18 tires 80% or newer F150 FX4 tires
  101. 99 XJ parts
  102. dodge 727
  103. Wanted: carrier/Differential for 91 f150. image of what i need
  104. DONE>>350 Exhaust Manifolds
  105. H&K model 91
  106. Looking to rent a log splitter
  107. Tj Fender
  108. Rear Windsheild Wiper Motor 97&Up Cherokee
  109. Wtb Running Sbf With Trans
  110. 00 xj hitch
  111. 88 XJ Oilpan, upper control arms, rear axle
  112. TJ Headlight Bucket w/ Adjusters
  113. Mighty Vac BOUGHT ONE
  114. dana 60 hubs and spindles??
  115. WTT 35" Tire for 33" Tire
  116. 35 - 37x12.50 17
  117. Suburban Parts!!!!!!.
  118. Lots of XJ stuff...mostly aftermarket.
  119. D35 3.73 rear ring and pinion needed
  120. Rear Drive Shaft - Needed 78 CJ-7 **
  121. Scrambler Project Wanted
  122. 2 bfg mt's, 35x12.50x16.5
  123. 73-93 dodge front clip
  124. yj fenders
  125. plow for 2005 duramax
  126. Needed: T-14 transmission
  127. naked lady mudflaps
  128. need stock tj suspension parts asap
  129. Concrete Work
  130. h2 wheels or a 17 inch 8 lug wheel
  131. TJ seat sliders
  132. 2000+ F150 supercrew
  133. 35"-40" Radial Tires for 16" or larger wheels, and 8 lug wheels for them
  134. 16inch 8lug wheels
  135. Looking for CJ5 under $1000
  136. Shot in the dark!!!!! Lift kit for Durango
  137. 8.8 axle
  138. 4 30X9.5XR15 Wanted
  139. soft door skins/and a trans
  140. *~* XBox 360 *~*
  141. I need shifter boots for my 93 YJ 5 speed
  142. WTT: warn TJ rockcrusher bumper with tire carrier
  143. Swaybar disco's
  144. Wanted Canyon Style Rims Also Tires If Possible Trade Or Cash
  145. parts for a cj and a wangler
  146. 4 inch tj springs
  147. tj front d shaft
  148. 35x12.5 R15 Wanted
  149. Ax-15 Tranny
  150. dog house
  151. torque converter
  152. WTB: NP231 from a 97-01 Jeep TJ
  153. AX-5 trans, prefer 1994 and later, junk ones are OK, too..
  154. drop pitman arm
  155. Rear overhead speaker pod for XJ
  156. AX5 parts needed for slave cylinder conversion
  157. pair of 235/75/15
  158. Cherokee Engine
  159. dana 300 or parts
  160. Looking for stock, late 80's jeep Wrangler!
  161. Complete XJ d30
  162. Golf Cart Body
  163. exhaust manifolds for a 1970 commando
  164. skid plate material
  165. Chevy wheel
  166. 10 Bolt Diff cover.
  167. d44 gears and carrier
  168. 8 bolt wheels
  169. Tahoe Door Panels
  170. WTB: Toyota EFI 22RE
  171. Center caps.
  172. Injection pump for 1999 Dodge Ram 3/4 ton diesel
  173. Rear seat belts for a TJ
  174. Fold and tumble rear seat for 03 Wrangler
  175. Wanted 2wd S10 Lift Spindles
  176. wtb 38's or bigger
  177. 6hp Horizontal shaft engine......
  178. KC Driving Lights
  179. All parts to swap a 93 4x4 explorer from auto to standard
  180. 4.0 Jeep motor
  181. Looking For 97-00 Dodge 1500 4x4 Ext.cab
  182. 98 ZJ radiator, good shape
  183. Need some cheap rims, or at least info
  184. Need Cam Sensor For 94 Explorer
  185. Header for a 304
  186. wtb 4.0 for a 02 wrangler
  187. Extra large Dog cage (Crate)
  188. '79 wag or chero gas tank
  189. lift coils for a TJ/ZJ
  190. ignition coils for 1999 4.0L ZJ
  191. Yj parts needed!
  192. tires
  193. front driveshaft
  194. Roll around wheels with tires chevy 5x5
  195. really small rollers for tj?
  196. AX15 bellhousing
  197. yj window frame
  198. 4.3 V6 block
  199. CJ drive shaft 33" CTC
  200. Stock XJ front track bar
  201. half doors windows
  202. looking for Dana 44
  203. Wtb 231 T-case
  204. Diesel K5 Blazer/Jimmy or manual trans Bronco
  205. Small truck like s10,ranger,sonoma wanted!
  206. 95 grand cherokee parts
  207. cj5 radiator 6 cyl
  208. snowmobile
  209. steering linkage, drop pitman arm 81 cj7
  210. WTB Extended Radius arms for a Ranger
  211. LCD monitor
  212. Need a cheap cheap cheap winter driver!!!!
  213. need 38 tsl sx for 16.5 rims-need two good ones
  214. Windshield for a CJ
  215. wtt: 96 neon
  216. wanted 73-87 sbc manifolds
  217. Wanted 1979 CJ7 Frame
  218. RUBICON MOAB wheels and tires
  219. 95 tahoe 241 transfer case
  220. Smoker Vent Window for YJ
  221. WTB..GM 4 cyl stick shift RWD vehicle ay condition
  222. 94 dodge 1500 axle shafts
  223. ramcharger body
  224. Black soft top
  225. Long shot...trans for taurus
  226. Wanted mig or arc welder
  227. YJ hood prop rod
  228. 92 s-10 drivers door or lock mechanism at the least
  229. WANTED: Rear Seat For CJ
  230. small diesel engine 1-2 cyl.
  231. 97-up XJ Front Panels
  232. PII Laptop or bigger
  233. Amc V8
  234. Pass Front Fender For 94 Explorer
  235. Looking For 80's F150
  236. 4l60e
  237. suzuki sami for winter project
  238. 2" receiver hitch rack
  239. hitch rack
  240. i need 2 37 12.5 15 goodyear mtrs
  241. WTT hard halfs for full hard doors
  242. Gas Tank & Sending Unit 92 S-10
  243. TJ fender Flares
  244. Demon Fuel line
  245. d44 lock-outs n dodge parts
  246. samurai driver rear axle shaft
  247. 16x10 5 on 5.5 wheels
  248. Looking to buy a Jeep!!!!!!
  249. 351 windsor
  250. Rear DS tail light Assembly
