Wanted [Archive] - Page 24 - Great Lakes 4x4. The largest offroad forum in the Midwest
  1. ford ranger/bronco2/explorer
  2. 33 x 12:50 x 15 super swamper TSL's
  3. Need 8.8 rearend.
  4. TJ Replacement Tailgat Bar
  5. TJ fuel sending unit
  6. Dana 300 transfer case
  7. 2000 TJ multi-function switch (brights/turn signal)
  8. Wanted: Set of 35x12.50R15LT
  9. need 1999era xj parts
  10. need drivers side taillight asap 99 XJ
  11. Wanted: Clean 71-83 Cherokee / Wagoneer Tailgate
  12. F-head
  13. 16x10 wheels
  14. 2 1/2"
  15. Seat frames for a CJ2A or CJ3A
  16. mopar 360
  17. title for gmc suburban
  18. fence
  19. yj radiator
  20. Looking for a good daily driver
  21. Wanted Cj7!!!!
  22. Truck tool box
  23. CJ Steering Shaft
  24. FABRICATOR!!! Near GR or in MI!!!
  25. Electric Fan for 2.5 94jy
  26. Soft Top w/o Hardware
  27. TJ Flares
  28. 98 TJ Hard Top
  29. WTB cj-8 Frame
  30. big block chevy egr block off plate. anybody?
  31. Cheap 4x4 Dodge
  32. 77 chevy 350 heads
  33. NP231 front yoke.
  34. Any axle With 4.56 Besides a Dana 35
  35. West side coil spacers
  36. Birthday Invitations?
  37. looking for a mini fridge
  38. trannys and t-case
  39. alloy shafts d44
  40. TJ Flares
  41. Ford 80-96 bucket seats & center console
  42. Electrical chord/plug ends
  43. need new 33''x10.5'' all terrains for winter
  44. need brush guard, front/rear bumpers
  45. wanted wood for heat
  46. 30x9.50x15's or 235/??-15's needed
  47. Wrangler ashtray
  48. TJ Radio antenna
  49. Dana 44 4.56
  50. Radiator for TJ 4.0 automatic
  51. 16x10 6 lug rims for chevy
  52. winter garage space
  53. auto trans 2.5
  54. looking for some metal to make shock tabs
  55. Seat belt
  56. Dana 44 Rear Axle
  57. a small motorcycle
  58. 12'-14' Aluminum Boat
  59. drivers side rear quarter window, pre-97 xj
  60. Spare tj dana 35 shafts
  61. Mid 80's 2wd Shortbox f150
  62. Red XJ Body Parts
  63. Needed for 99 TJ--(stock) Front Swaybar Endlinks
  64. Gears for 99 XJ Dana 30 and 35
  65. CJ7 Body Mounts [Qty (2)]
  66. WTB: pair of shocks
  67. Ax15 or NV3550
  68. YJ D35 4.10s
  69. Ford 8.8 axle
  70. WTB. dodge fender flares
  71. 1990 YJ tops
  72. Need a Job around Big Rapids
  73. Goose Decoys
  74. stock front TJ bumper
  75. Mid 90's XJ
  76. D44 lock outs
  77. Header for 1994 YJ 4.0l
  78. To Borrow: Folding Engine Hoist
  79. 17" rim with 5 on 4.5 bolt pattern
  80. CJ-7 driveshaft 32.5" to 35.5"
  81. Stock XJ upper control arms
  82. Radio 94 wrangler
  83. looking for some rims
  84. Well, that was short lived.
  85. Front Clip for 95 Wrangler
  86. WTB: Laptop RAM
  87. WTB: Laptop HD
  88. 33"X12.5X16" Tires
  89. need a bw1339 (quadratrack) t-case
  90. wanted vw motor
  91. Seats and roll bar for a 3a?
  92. Need spare for YJ 33" A/T style ?
  93. looking for a cheap TV 24"+ and small entertainment center
  94. Running chevy engine with fuel injection already set up
  95. Wish List (need parts for a ranger, and jeep coils)
  96. Lift kit for an xj
  97. 15x12 rims
  98. Wanted stock YJ windshield hinges
  99. YJ guages
  100. Auto Trans
  101. Auto Trans - 16.5 Rims
  102. 315/75R16's
  103. WTB: used extended cab dually truck
  104. KC light covers
  105. good runnin chevy tbi or carb v8
  106. 6" chimney pipe for wood furnace
  107. Aftermarket ford rims 16" 5 on 135MM
  108. 5.13 gears for HP D44
  109. 72-77 Heater Parts
  110. s-10 Front differential 3.73 AND 02+ Dodge Tailgate
  111. radiator for 88 jeep comanche
  112. cj soft top
  113. 97 or newer tj
  114. BW 1354 Manual Tcase
  115. WANTED - Black int. pieces and seats for TJ
  116. Need to borrow/rent a car hauler for a weekend
  117. chevy np205
  118. TJ Fenders
  119. Nvm
  120. 2.3 ford inline 4
  121. zj adj trac bars
  122. wtb xj leaf packs
  123. toyota wheel spacers and spare 35" tire
  124. bench or bucket seats for comanche
  125. WTT: 3 month old 32in Dunlop Mud Rovers
  126. 4.6/4.7 Stroker for 2000 XJ
  127. verizon cell phone
  128. XJ Mechanical Fan Shroud
  129. MPI 2.5L engine harness, dash harness and computer
  130. cheap DD truck
  131. 47RE Core
  132. spray gun
  133. WTB: 1990 Geo Tracker stuff
  134. HP d30 4.10 and 8.8 4.10
  135. shifter
  136. Wanted Ford NP208
  137. 4" lift coils for tj
  138. Front fenders for a 99 XJ
  139. Willys flatfender jeep (CJ2a or CJ3a)
  140. CRT monitor
  141. DD that your willing to trade for my cj
  142. washer/dryer
  143. WTB Trans Cooler Lines 94ZJ 5.2L
  144. ring and pinions
  145. adjustable tj front track bar
  146. Want a PS2
  147. XJ dana 30
  148. Walker Evans Beadlock Rims
  149. Old style camper rims
  150. small game gun
  151. chevy Front 10 bolt axles shafts both sides
  152. XJ front shocks, Brake Lines
  153. xj front drive shaft
  154. YJ front driveshaft
  155. XJ/ZJ pitman arm
  156. 00' Chevy Silverado Parts Needed
  157. np249
  158. k5 tale gate
  159. Weight bench & free weights
  160. stock inner rubicon axle shafts
  161. WTB 16-20' car hauler
  162. yj tcase skid
  163. sahara front seats
  164. 91 older yj speedo sensor thingy
  165. dana 30 locker and roll cage
  166. Cheap 6 Lug Rollers
  167. Kreitler Rollers (attn: bicyclists)
  168. 4:1 kit for an NP231
  169. front hitch reciever, 95 K3500 chevy
  170. 4cyl: non return fuel rail
  171. Jeep NP231
  172. pallet rack/shelf
  173. verizon cellphone
  174. wheel horse garden tractor
  175. Gas Tank Skid 97-01 XJ
  176. Truck Avenger
  177. NEED ASAP: 99+ PS bracket/pump
  178. 2.5 starter needed
  179. Junk Rear axle D35 Set up with TJ Brackets
  180. 2 barrel carb for a 68 mustang 289
  181. Jeep 4.0 engine or block
  182. Dually 14 bolt
  183. 94-95 4Runner
  184. Driveshaft for 28.25" c-c CJ5
  185. Ps2 & Nes
  186. Dana 300
  187. Hunting Land Wanted
  188. looking for a good used 10x16 or 12x16garage door
  189. AMC 20 4.10 gears
  190. tube doors
  191. trans. 98 caravn
  192. 700r4 to Dana 300 Stub Shaft
  193. Toyota PU parts
  194. Need 4x4 DD/Wheeler under $5000
  195. yj dana 30
  196. WANTED: Good used D44 front outer axle shaft
  197. wtb 4.3 chevy motor
  198. (2) 16" tires
  199. Dana 35 3.73 ring and pinion and carrier (rear)
  200. Flatbed Trailer
  201. jeep yj 2.5 motor
  202. Need 95 YJ rear springs or used lift
  203. dana 300
  204. Wanted Big Swampers or Boggers
  205. old nintendo games
  206. WTB: 8.8 or rear TJ dana 44
  207. WTT my FT ultimate kit and cash for a long arm
  208. 304 or 360
  209. xj leafs or any 2.5" wide 52"+ leaf spring
  210. trade 231 t-case for a 242
  211. Hp30
  212. motorcraft carb
  213. Wanted Bronco or any other 4x4
  214. 78 fullsize ford 4 inch lift springs
  215. dana 35 yoke
  216. Cheap to free: Front pass. door for a 01 4dr XJ
  217. front stock yj leafs
  218. need a trailer hitch
  219. 318 2wd OD auto tranny
  220. F150 D44 Axle shafts
  221. yj doors
  222. trailer/tow dolly to borrow grand rapids area
  223. I want a Tj
  224. steam cleaning
  225. Drive shaft for 304 CJ5 21" c-c running length
  226. Driveshaft for a 1982 ford f-150
  227. 350 turbo trans
  228. WTB: nice CJ7 or maybe a yj even
  229. 2wd tracker trans
  230. samari t case
  231. Looking for a YJ Pig Gig parts
  232. looking for a cheap bronco 2
  233. WANTED!! XJ Headlight parts
  234. Looking for my old 1978 CJ7 "mudweiser"
  235. doors / top
  236. Doors for 96 Dodge Ram
  237. front drive shaft
  238. Unlimited Hard top
  239. 35x12.5x15
  240. I need 38's or 39's for 17"wheels HELP!!!!
  241. YJ Hard Doors or Round Uppers
  242. amc 20 narrow track offset rear axle
  243. wtb set of 38's
  244. power window motor
  245. Contact info where I can get a custom speedo cable made?
  246. 1995-02 mustang
  247. Tickets for brad paisley
  248. Durango Steering Box
  249. Walk behind snowblower
  250. tj seat brackets
