Wanted [Archive] - Page 23 - Great Lakes 4x4
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 [23] 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48
  1. 30's or smaller
  2. trans
  3. Autometer Tachometer
  4. Looking for a Kia Sportage Motor 2002
  5. wtb- 2.4l cavalier/ sunfire motor
  6. T-5
  7. 2 sit down jet skis with trailer
  8. camber adjustment bolts for tj
  9. moped
  10. XJ Lockers
  11. Swing Out Tire Carrier
  12. 99xj power window assembly
  13. Seat Belt
  14. wtb. dana 44 locker
  15. Seat belt
  16. Wanted:TJ (Cash in Hand)
  17. Need to BUY CAR HAULER
  18. Bronco 2 gas tank
  19. needed for 97TJ/stock front shocks and non disco's"GOT M"thx jeeps4us/plz delete
  20. AMC 360 Flywheel for a Manual Trans
  21. dana 30 front with 3.73 gearing
  22. 1987-1995 Zf S5-42
  23. XJ stuff & 31-33" tires
  24. WTB: A few TJ items..
  25. Need Bumper for 95 Cherokee!
  26. need some fun toys
  27. waggy shafts, HPD44 Parts, 9" parts
  28. YJ 4.0L PCM and wiring 91+
  29. Need 99 wrangler parts
  30. 31 spline 8.8 posi carrier
  31. Cherokee door lock actuator and lift motor
  32. jeep zj
  33. Steel Winch Cable
  34. cj gas tank
  35. chevy s10 blazer hitch 2" 2002
  36. 94 YJ tub
  37. 94 yj tailgate
  38. Starter 1991 Cherokee 4.0
  39. XJ shocks
  40. 4.88 gears for LP D44
  41. someone to install a clutch
  42. trans for 96 ZJ auto
  43. car hauler?
  44. zj skids
  45. stock XJ front sway bar links
  46. My circuit board for the speedometer is toast.
  47. WTB: Headlight panel/grill 99 xj
  48. Trade my cj7 for a quad or dd
  49. bronco top
  50. 33" Tire SILVER LK AREA**ASAP**
  51. Need Stock Leaf Springs For Cherokee 94
  52. Wanted F & R driveshaft’s 95 YJ 4.0L
  53. ZJ,TJ coil spacers
  54. wtb or trade for zj or xj
  55. TJ back seat wanted
  56. ax-15
  57. mic for cobra cb
  58. Yj hard top
  59. WANTED: older dodge diesel
  60. Sailboat
  61. TJ fold and tumble rear seat, and carpet.
  62. tj windshield frame
  63. aw4 from 91-96 cherokee need
  64. cj5 window frame
  65. cj door hardware
  66. Scrambler
  67. rollbar
  68. Chevy 63" leaf springs?
  69. XJ lift
  70. 96-98 grand cherokee 4.0 ECM
  71. ford Taurus fan
  72. Tranny rebuild
  73. superduty leaf springs
  74. CJ speedometer
  75. TJ Full doors
  76. 33"Tires
  77. toyota axles
  78. WTB 31x10.5x15 MT or AT's
  79. Electric golf cart - must have 4 wheels for stability
  80. shackles
  81. 15" 8 lug rims
  82. axles and gears
  83. D35 Spider gear washers (new or used)
  84. 99-up Chevy Tailgate
  85. WTB: Boat
  86. Spider Gears or a cheap locker for 29 spline 8.25
  87. 700r4 4 wire trans connector. Will pick up today!
  88. .
  89. Need 2.5L for 98 Wrangler
  90. needed TJ front bumper and......
  91. dirtbike muffler
  92. Front 3:73 diff. for pre 94 S-10
  93. good working laptop
  94. leaf sprug dana 30 or 44 now???
  95. cj5 heater parts needed
  96. XJ Passenger Fender
  97. struts for truck topper/shell/cap
  98. Golf Clubs/Budweiser golf umbrella
  99. 63" chevy springs
  100. Pit Bike or similar
  101. Dodge 440
  102. CJ 7 Steering column
  103. 4.88 Hp D30 R & P
  104. XJ Carpet
  105. TJ door surround through bolt
  106. Wanted: factory gauges for 94 yj
  107. Wanted extended cab truck
  108. Cheap Quad
  109. 84-89 4Runner
  110. 1997-2002 BLAZER/JIMMY 2 DOOR sending unit
  111. 32x11.50 Tire - Mid MI?
  112. Chrome TJ grill
  113. Need A 93 CHEROKEE WINDOW/ DOOR
  114. Wanted Alternator for 96XJ
  115. WTT Coilovers
  116. Wanted Jeep CJ
  117. R.E TJ Long arm Belly pan for a 2000
  118. CJ carb spacer
  119. Flowmaster
  120. WTB YJ or TJ 4 Cyl Front Driveshaft
  121. Dental receptionist
  122. Drw Dana 60 hubs(not needed anymore)
  123. 3500 watt and + generator
  124. ax15 tranny
  125. Wanted: TJ Center Console
  126. radiator
  127. 31" tires
  128. 94-01 Ram Power Window/Door Lock Switch
  129. jet boat
  130. Engine stand
  131. WTB: Threaded Inserts For Hide-A-Trunk Mounts for a Jeep Wrangler
  132. Jeep Cherokee Dana 44 rear axle Or even a ford 8.8 with 3:55 gears
  133. drop pitman wanted
  134. Set of 8 lug rollers
  135. Fan Shroud
  136. revolver
  137. Small Fridge
  138. Wanted**Tuffy stereo console***Black
  139. zj grand lift
  140. Brake Calipers 83 CJ7 Both Front
  141. TJ yolk needed front
  142. wtb or trade for 30", 31" or 33" tires.
  143. 70 - 90 hp outboard boat motor
  144. Cheap Car
  145. Trade shotgun for rims and tires
  146. trade car audio for mountain bike
  147. cheap 4 wheeler or 3 wheeler
  148. single 35x15 tire for spare.
  149. Looking for a T/A bodyshell
  150. 6 lug 16"x8-10" wheels
  151. Nitro R/C truck ****Now with pics****
  152. dana 30 locker
  153. model a/t parts
  154. Wtb Dual battery tray
  155. chevy rally wheels
  156. Cheap to Free throttle cable for chevy
  157. Center console for TJ
  158. Mud tires 38"-40 inch
  159. wtb: gm 14 bolt ff
  160. Still looking for a tub.
  161. TJ dana 44 front axle
  162. Wanted: Rear TJ Fender Flares
  163. stock tj bumpers
  164. 1 pallet (for shipping)
  165. set of h2 wheels
  166. 4.0 non HO harmonic balancer and timing chain cover
  167. Wanted: CJ/YJ Carpet, Console, tire carrier
  168. WTB: Wrangler or CJ (or other)
  169. 2500-3000 stall converter and aluminum radiator for cj
  170. Jeep J-20 Steering Box
  171. geo tracker hard top
  172. YJ steering box
  173. 4" lift spings
  174. Used Refrigerator
  175. fsj axle shaft or rubicon axle shaft needed badly
  176. Hitch Reciever
  177. 78 cj spring plate
  178. CJ7 Tub Corners guards
  179. cj wide track axles
  180. HEI distributor for SBC 350
  181. WTB cj wheel spacers 5x5.5
  182. 4.56 gears for an 8.25
  183. new YJ steering box, or any/all components for a ram assist setup.
  184. varmint rifle .223 prefferably
  185. Needed UCA"s ASAP
  186. wanted trubo 350 tranny
  187. 97 TJ turn signal switch ###GOT ONE###
  188. Car hauler!
  189. Jeep
  190. Trailer hitch for an XJ
  191. 2 235x75-15 BFG A/T
  192. 70-80s 4x4 chevy truck
  193. CJ7 Radiator, Windshield Glass, Corner Guards
  194. 351 windsor
  195. Saw Mill
  196. 4.3 1995 Cpi Motor "runner"chevy
  197. '66-'71 Jeep Commando
  198. tracker oil pan, maybe a clutch
  199. tow hooks for '04 WJ
  200. need full steel doors for yj ,cj
  201. TJ/YJ/CJ 1/2 soft doors
  202. Looking for a 700r4
  203. TJ Front Coil Insulator Pads
  204. Need d 60 carrier for 5.13 gears
  205. TJ rear seat
  206. 2.5L 4cyl
  207. Chrome headlight bezel
  208. AMC V8 Radiator
  209. 99+ I6 intake
  210. d30 knuckle for a 92 yj
  211. 60 front
  212. YJ fueltank
  213. Empty Dana 20 T-Case Housing
  214. toyota front driveshaft
  215. 350 headers for a cj
  216. Chevy Body Mounts?
  217. tj RE lift springs
  218. YJ lift
  219. wanted: black tj hardtop
  220. 4.10 r/p for d30 hp
  221. Old road bicycles and or cruiser
  222. Winch
  223. alternator for a 2.8L multiport 1985 camaro.
  224. B&M shifter
  225. 1990ish Toyota 5 speed manual trans
  226. Bellhousing
  227. H1 Rims
  228. Stock XJ Pitman Arm
  229. HEI distributor
  230. OEM GM 8 lug Aluminum Rim 1 or complete set
  231. tj center dash piece
  232. pool filter motor
  233. WTT '88 F-350 Dana 60 for chevy 60
  234. 20.5" rear and 28.25 frnt driveshafts '73 CJ5
  235. Wagoneer pitman arm
  236. Need XJ Accessories
  237. 33 12.5 R15 Mud Terrain close to muskegon?
  238. Want to borrow a trailer
  239. Thanks!
  240. 2'' coilspring spacer for xj
  241. i'm looking for a jeep zj or xj
  242. 3 pt york rake
  243. dead trees
  244. `77 t0 `80 Dodge Pick up parts....what you got?
  245. Seat Belt
  246. sbc rams horn exhaust
  247. Wagoneer pitman arm
  248. crappiest full yj hard door you got
  249. wtb factory stereo for 02 wrangler
  250. rear yj upper shock mounts
