Wanted [Archive] - Page 21 - Great Lakes 4x4. The largest offroad forum in the Midwest
  1. yj tailgate
  2. 1991 xj steering column
  3. warn- tire carrier, TJ slider windows, tires, wheels, ect.
  4. wtb 4x4 quad
  5. WTB Tj dana 30 w/ 4.10 gear
  6. front fender flair for cherokee
  7. set of 4 5x5 1/2" 15 inch ford, jeep, suzuki wheels
  8. Driveshaft assembly for '98 polaris XC 600
  9. 2.5 tbi 90 yj
  10. WTB: 33 x 10.5 x 15 TIRES, Mud, AT, etc, what you got?
  11. CJ7 Carb
  12. i need someone to groove my tires
  13. Input gear for 203 t-case
  14. GM supercharger oil
  15. 231 Chain
  16. 92-93 AX-15 for my XJ
  17. Ax5
  18. Working 2wd Ford C6 Trans to bolt to a 460
  19. Dune Flag to borrow
  20. Nextel Flip phone that I can put my sim in.
  21. 4.0L Jeep TJ Throttle Body
  22. bare 14 bolt axle
  23. 7-10 gal. air tank/smaller narrow truck box. where to buy??
  24. Wanted ASAP!! Trans Cooler lines for a 94 ZJ 4.0w/a500 Trans
  25. a trans jack
  26. 5 speed tranny for 99 tj.
  27. Wanted Car hauler
  28. nerf bars or steps
  29. need a diesel 4l80 4wd
  30. YJ spring hangers
  31. Electric start bike motor.
  32. Steering Gear Box - GOT IT
  33. WTB TJ Trunk
  34. CJ-7 wtb 373 gears front axle needed
  35. 700r4 torque converter
  36. WTB - 02 Ford F-150 Bed Cap
  37. WTB D30 axle shafts
  38. D44 carrier
  39. wanted 75-83 chevy dana 44 calipers and rotors
  40. D6O Ford outer knuckles
  41. 2002 raptor service manual
  42. POS jeep or truck
  43. Superduty
  44. 22re toyota engine
  45. Got One..
  46. Full SIze D44 Chevy/GM 73-77 axle
  47. WTB - Jeep YJ or CJ
  48. Computer 93 Gr. Cherokee
  49. Need ford NP205 input gear, married
  50. Wanted - CJ windshield & frame
  51. WTB 6x5.5 BP wheels 17"
  52. stock tj wanted
  53. dana 60 locker.
  54. 35Inch Spare
  55. dana 44 knuckle
  56. Jeep Wrangler TJ Windshild Channel
  57. TJ front seat drivers side
  58. CJ 5 Body?
  59. 235/80/r17 Tires
  60. wtt- xj parts for xj lift
  61. 16.5 rims
  62. ***WANTED:YJ Manual steering box***
  63. d60 parts
  64. 8.8 Rear axle
  65. 10bolt got a set thanks
  66. 78 cj5 soft top
  67. 8 lug Chevy 15 X 10 Aluminum Wheels
  68. wtb 4.3chev parts
  69. WTB: a canoe
  70. Wanted-- Mirrors when the doors are off TJ
  71. Unlimited OffRoad Center, looking for showroom help.
  72. 73- 87 chevy blazer or truck clutch braket needed
  73. 30's or smaller
  74. trans
  75. Autometer Tachometer
  76. Looking for a Kia Sportage Motor 2002
  77. wtb- 2.4l cavalier/ sunfire motor
  78. T-5
  79. 2 sit down jet skis with trailer
  80. camber adjustment bolts for tj
  81. moped
  82. XJ Lockers
  83. Swing Out Tire Carrier
  84. 99xj power window assembly
  85. wtb. dana 44 locker
  86. Seat belt
  87. Wanted:TJ (Cash in Hand)
  88. Need to BUY CAR HAULER
  89. AMC 360 Flywheel for a Manual Trans
  90. dana 30 front with 3.73 gearing
  91. 1987-1995 Zf S5-42
  92. XJ stuff & 31-33" tires
  93. WTB: A few TJ items..
  94. Need Bumper for 95 Cherokee!
  95. need some fun toys
  96. waggy shafts, HPD44 Parts, 9" parts
  97. YJ 4.0L PCM and wiring 91+
  98. Need 99 wrangler parts
  99. 31 spline 8.8 posi carrier
  100. Cherokee door lock actuator and lift motor
  101. jeep zj
  102. Steel Winch Cable
  103. cj gas tank
  104. chevy s10 blazer hitch 2" 2002
  105. 94 YJ tub
  106. 94 yj tailgate
  107. Starter 1991 Cherokee 4.0
  108. XJ shocks
  109. 4.88 gears for LP D44
  110. someone to install a clutch
  111. trans for 96 ZJ auto
  112. car hauler?
  113. zj skids
  114. stock XJ front sway bar links
  115. WTB: Headlight panel/grill 99 xj
  116. Trade my cj7 for a quad or dd
  117. bronco top
  118. 33" Tire SILVER LK AREA**ASAP**
  119. Need Stock Leaf Springs For Cherokee 94
  120. Wanted F & R driveshaft’s 95 YJ 4.0L
  121. ZJ,TJ coil spacers
  122. wtb or trade for zj or xj
  123. TJ back seat wanted
  124. ax-15
  125. mic for cobra cb
  126. Yj hard top
  127. Sailboat
  128. TJ fold and tumble rear seat, and carpet.
  129. tj windshield frame
  130. aw4 from 91-96 cherokee need
  131. cj5 window frame
  132. cj door hardware
  133. Scrambler
  134. rollbar
  135. Chevy 63" leaf springs?
  136. XJ lift
  137. 96-98 grand cherokee 4.0 ECM
  138. ford Taurus fan
  139. Tranny rebuild
  140. superduty leaf springs
  141. CJ speedometer
  142. TJ Full doors
  143. 33"Tires
  144. toyota axles
  145. WTB 31x10.5x15 MT or AT's
  146. Electric golf cart - must have 4 wheels for stability
  147. shackles
  148. 15" 8 lug rims
  149. axles and gears
  150. D35 Spider gear washers (new or used)
  151. 99-up Chevy Tailgate
  152. WTB: Boat
  153. Spider Gears or a cheap locker for 29 spline 8.25
  154. 700r4 4 wire trans connector. Will pick up today!
  155. .
  156. Need 2.5L for 98 Wrangler
  157. needed TJ front bumper and......
  158. dirtbike muffler
  159. Front 3:73 diff. for pre 94 S-10
  160. good working laptop
  161. leaf sprug dana 30 or 44 now???
  162. cj5 heater parts needed
  163. XJ Passenger Fender
  164. struts for truck topper/shell/cap
  165. Golf Clubs/Budweiser golf umbrella
  166. Dodge 440
  167. CJ 7 Steering column
  168. 4.88 Hp D30 R & P
  169. XJ Carpet
  170. TJ door surround through bolt
  171. Wanted: factory gauges for 94 yj
  172. Wanted extended cab truck
  173. Cheap Quad
  174. 84-89 4Runner
  175. 1997-2002 BLAZER/JIMMY 2 DOOR sending unit
  176. 32x11.50 Tire - Mid MI?
  177. Chrome TJ grill
  178. Need A 93 CHEROKEE WINDOW/ DOOR
  179. Wanted Alternator for 96XJ
  180. WTT Coilovers
  181. Wanted Jeep CJ
  182. R.E TJ Long arm Belly pan for a 2000
  183. CJ carb spacer
  184. Flowmaster
  185. WTB YJ or TJ 4 Cyl Front Driveshaft
  186. Dental receptionist
  187. Drw Dana 60 hubs(not needed anymore)
  188. 3500 watt and + generator
  189. ax15 tranny
  190. Wanted: TJ Center Console
  191. radiator
  192. 31" tires
  193. 94-01 Ram Power Window/Door Lock Switch
  194. jet boat
  195. Engine stand
  196. WTB: Threaded Inserts For Hide-A-Trunk Mounts for a Jeep Wrangler
  197. Jeep Cherokee Dana 44 rear axle Or even a ford 8.8 with 3:55 gears
  198. drop pitman wanted
  199. Set of 8 lug rollers
  200. Fan Shroud
  201. revolver
  202. Small Fridge
  203. Wanted**Tuffy stereo console***Black
  204. zj grand lift
  205. Brake Calipers 83 CJ7 Both Front
  206. TJ yolk needed front
  207. wtb or trade for 30", 31" or 33" tires.
  208. 70 - 90 hp outboard boat motor
  209. Cheap Car
  210. Trade shotgun for rims and tires
  211. trade car audio for mountain bike
  212. cheap 4 wheeler or 3 wheeler
  213. single 35x15 tire for spare.
  214. Looking for a T/A bodyshell
  215. 6 lug 16"x8-10" wheels
  216. Nitro R/C truck ****Now with pics****
  217. dana 30 locker
  218. model a/t parts
  219. chevy rally wheels
  220. Cheap to Free throttle cable for chevy
  221. Center console for TJ
  222. Mud tires 38"-40 inch
  223. wtb: gm 14 bolt ff
  224. Still looking for a tub.
  225. TJ dana 44 front axle
  226. Wanted: Rear TJ Fender Flares
  227. stock tj bumpers
  228. 1 pallet (for shipping)
  229. 4.0 non HO harmonic balancer and timing chain cover
  230. Wanted: CJ/YJ Carpet, Console, tire carrier
  231. WTB: Wrangler or CJ (or other)
  232. 2500-3000 stall converter and aluminum radiator for cj
  233. Jeep J-20 Steering Box
  234. geo tracker hard top
  235. YJ steering box
  236. 4" lift spings
  237. Used Refrigerator
  238. Hitch Reciever
  239. 78 cj spring plate
  240. CJ7 Tub Corners guards
  241. cj wide track axles
  242. HEI distributor for SBC 350
  243. WTB cj wheel spacers 5x5.5
  244. 4.56 gears for an 8.25
  245. new YJ steering box, or any/all components for a ram assist setup.
  246. varmint rifle .223 prefferably
  247. Needed UCA"s ASAP
  248. wanted trubo 350 tranny
  249. 97 TJ turn signal switch ###GOT ONE###
  250. Car hauler!
