- yj project in the detroit area
- cj pitman arm reemed out for 1-ton steering
- Jeep 2.5 Must run good (testing the waters)
- W.T.B running 4x4
- slide in truck camper
- set of descent 35's
- Early Bronco 44 front
- fact. YJ trans crossmember
- Frames for 1/2 soft doors
- 31" BFG Mud Terrain
- D300 & PassDrop44
- F-series computer
- YJ soft top rail. Just the driver side rear corner piece. bestop.
- dana 44 front axle spring plates
- Need a windshield
- Buick 4bbl Intake Manifold - NEVERMIND
- W.T.B 4x4 CHEAP WHAT DO YOU HAVE?
- TBI SBC motor
- TJ Front adjustable trackbar
- WideTrack CJ rear axle
- 5 Black Rims
- parts i need for 83 cj7
- 2 35" + Tires
- Dana 60 4.88 gears and locker.
- 4.0 engine
- car hoist
- 15x10 5 x 4.5 (TJ) RIMS
- 32" or 33" MT's
- High Steer Arms
- XJ or and MJ grill?
- Wanted Stove & Fridg
- CB Radio Setup for my TJ
- CJ axles
- Pair of leaf springs, just about any will work..
- wtb buy mud tires 35-37
- wanted Dana 20 or Dana 300 yokes
- wanted stock tj in trade for my xj
- NV242 wanted
- Ax-5
- wanted s10 driver door and front fender
- D35 yj drums
- Jeep CJ Steering Column
- MORE or RE TJ brackets for Ford 8.8
- chevy 8 bolt 15inch steel rims
- Wanted Car hauler or Utilty trailer 16 ft deck to haul a Jeep
- somewhere to live
- Sailboat
- York 210 Series Compressor for OBA
- 31's and 3" coils for XJ
- 94 ZJ front fascia/bumper
- Stock Jeep wheels and tire.
- TH350, TH400 or 700R4
- Free Cat5 ethernet cable
- Divorced NP205
- Good running 4X4
- CJ 3-6" lift SUA
- XJ HD track bar mount
- 2.5 YJ motor--stuff
- Need Parts.
- YJ steering shaft
- XJ lift shackles
- WTB 30x9.50x15 MTR or similar
- Center Caps for Cragar 397 Black Rims
- Two (2) XJ donut spare wheels/tires near GR
- Cheep DD under $2,000 wanted.
- WTB 29 or 30" BFG A/Ts
- outboard motor
- 4.0 Sensors (Engine temp and Oil pressure)
- 2" body lift
- WTB parts for 94 ski-doo
- Wanted Mig welder
- tires,wheels for rolling project
- 35 inch Xterrains or Swampers
- fender/frame
- crashed/rolled Rubicon
- TJ Brush guard
- FWD smashed or junk
- trade 35"s for 36"s or 37"s
- Trade some 35s for 37s?
- truck bed Tool box
- YJ/CJ tub.
- stock shackle hanger
- Coil Spacers (TJ)
- Smalle Fire Extinguisher
- CB Radio
- Stock CJ7 steering wheel
- 01 Dodge Ram parts?
- Tamiya TLT Axles
- Fuel Cell. at least 10 gallons. Must look pretty.
- RR ties, concrete, rocks, logs,ect wanted
- wanted trailer
- need tires and rims
- looking for very cheap 4x4
- need some bolts..
- Still looking for 35 inch tires
- 15x8 Black Steelies 5 on 4.5" 3.75" bs
- tires\rims\rollers
- Help me find a samuri!
- shocks for a TJ
- 15x10 Toyota/Chevy 6 lug Aluminum Wheels.
- 92-94 toyota truck bed tailgate
- waggy 6 bolt brake parts
- YJ windshield frame
- YJ spare tire carrier
- 258 Crank and Rods (possibly)
- 14 bolt FF wated
- tj factory soft top hardware
- 94-96 zj carpet
- waggy leafs
- Wanted Adjustable front track bar or relocate bracket
- Dana 30 front Axle early CJ
- 1.6l 8 valve
- rear shock mount for a tj
- 8' truck topper / cap / camper (?)
- Trail Rig /project
- chevy brake caliper brackets (dana 44)
- Clean (rust-free) TJ windshield and door hinges
- CB Radio
- Need 700R4!!!
- Cheap DANA 30 with 4.10s YJ
- Red passenger fender for 97 TJ
- imprtfightr seat
- NP241c clocking ring
- yj hitch
- ZF trans
- Tires
- truck wanted
- Someone Who Works for Comcast or Brighthouse.
- 36 in tirer
- YJ bumperettes
- TJ hood latch
- Divorce mounted D20
- Weber Carb for 258
- Need 1 31x10.5x15 mt style tire.....
- 91 ford sheetmetal
- 401 or 360
- Could use......
- TJ flares
- bell housing adapter
- 36" Spare
- new body
- chevy TH400 4x4
- AMC auto
- NEED HVAC HELP! No HEAT!
- looking for a tonnue cover
- Winch
- dana 30 yoke (pinion)
- looking for CJ7 Seats and YJ Leaf springs
- YJ center council
- 5.9 360, newer? low milage?
- 91 to 95 Ford 4.0 V6
- 5x5.5" wheels... Free to cheap.. for rollers....
- Wanted 2 16x38.5x16.5 TSL or boggers
- Chevy t-case shifter
- Parts needed for a 2000 TJ
- 15 inch tires
- CJ2A fenders
- 1968 Chevy Nova Door skins or full doors
- I need a timing chain for a 90 2.5 Tech4
- CJ5 Soft top & doors
- 16" rims
- Tires Purchased - Thanks
- Tj D30
- bypass fuel regulator
- Block for a Cherokee
- Dana 30 WT
- Chevy truck pass. side fog light 99-05
- 14 bolt, no gov-lock, I need an open diff. Stan stole my rear axle, I need a new one
- Project-cheap-anything
- strong front axle.. driver side drop..
- NV242 Transfer Case
- 1 or 2 40" ground hawg
- Electric wheelchair or Amigo
- who has a metal break for 1/8 th in plate
- TJ Shifter boot
- WTB Chevy 2wd truck Full size or S-10
- Chevy Insp. plate, and clutch fork boot
- 8 lug, 15" rims to fit a corp 14 bolt. 2 wagons, or 4 matching.
- 8 lug front hubs for waggy 44...
- 4.5" XJ coils
- Head for a 91 4.0
- AMC V8 timing cover!!!!!!!!!!!!!!!!!!
- 36x12.5x15 swampers
- 03 kfx 400 f/s or trade
- Cherry Picker
- 38+" tires for 16.5" rim
- WTT My XJ for a TJ
- 1 33 for spare
- parts for yj
- WTB: YJ rolling project up to $1,500.00
- 4" lift
- XJ exhaust 2.5L
- Jeep Wrangler YJ
- cj5 body
- 4.0 exhaust manifold
- 2" Budget Boost Kit
- YJ Tub or YJ Wrangler
- Wider TJ Fenders
- Lookin For.
- YJ Windshield
- Power steering parts for inline six non4.0L
- set of rims...
- scrambler front rollcage
- TJ Parts for my YJ
- 31 inch AT's or mud terrains
- Dana 44 cover and/or guard
- need some stuff for a 1993 xj
- liftn' my yj
- TJ flares
- xj/ 2" lift shackles
- 8.8, 4.10, disks, limited slip
- Output gear on T14 tranny
- 2.5L yj oil pan
- Cheap CD deck for my YJ....this will now be my 3rd
- toyota leaf spings..
- d30 RH side split shaft for 297 joints
- tail light 2000 cherokee
- need bigger TIRES
- Black tj soft top & some hardware
- tires for yj
- ARB Snorkel
- 3\4 ton springs
- yj body parts
- Scrap metal pick-up in SE Oakland county
- 265/75/16 or bigger truck tires
- Amc 400
- WTB 33-36's set of 4
- 14 Bolt Axle! My last deal fell through.. I can pick up today!.
- jeep rims needed
- 4.5" XJ Coils
- cj-7 soft top
- exmark mower
- Spare Tire w/ rim
- CJ7 Drivers side door
- who has some 2 1/2" wide schacle mounts?
- Cheap car for bumper tag!
- 31x10.5 r15 AT tires
- 4X4 Truck
- Turbo 350
- deleted
- Toyota 22R or 22RE engine
- 6" lift coils 4 a 79 f150
- YJ belly Pan
- Cheap car/truck
- 36" Swampers
- Another Flat Fender Project
- Trail Cover for Cj5
- Two piece soft doors/hit
- CJ drop pitman arm
