Wanted [Archive] - Page 18 - Great Lakes 4x4
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 [18] 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48
  1. seatbelts,battary,alternator,windshieldwiper switch
  2. Set of Hummer rims H1
  3. Project xj in west mi
  4. ZJ Seats, both front, black leather, power, heated.
  5. ford bronco
  6. wanted 80 style cars caprices,etc that run.
  7. rubicon
  8. Ford Bronco Body
  9. fuel pump 4 grand cherokee
  10. Dana 300 with flip kit WANTED
  11. WANTED JET CHIPJet Chip Jeep 4.0 Stage 2 90015S
  12. 1973-1979 Ford truck cab
  13. Stock exhaust for '00 GM 2500 - NEVERMIND
  14. WTF 86 bronco fender flares
  15. Winch
  16. Wanted 05 TJ Speaker Harness
  17. I Need Axel Set
  18. wanted: yj radiator
  19. looking for a 2 1/2 or a 3 inch miffler
  20. wanted: Distributor for 94 4.0
  21. Rear Axle Chevy Blazer
  22. front flare from a 97+ xj
  23. airstream camper
  24. Rubicon 44 front axle complete
  25. wtb: Allis Chalmers "B"
  26. 700 to 208 adapter/trans mount
  27. 10 Bolt Carrier!.
  28. asap. 95 yj driver's side mirror
  29. Rubicon express SOA 2" YJ packs. I only need the front.
  30. a pony
  31. 96-98 ZJ Memory Module from LF Door
  32. ford d28 axle studs
  33. rubicon coil springs
  34. Xj under 2 grand
  35. rocker guards
  36. Car Dolly
  37. friend needs rear soft window for TJ
  38. need 8v tracker/sidekick motor...
  39. Axle shafts
  40. TJ flares
  41. *
  42. Bw1350
  43. 15x8 aluminum rims
  44. dodge 3.9 engine
  45. YJ heater
  46. YJ Wheels
  47. looking for a jeep
  48. need a fuel injected 350.
  49. XJ sway bar links
  50. 30 spline dana 44 locker/lt'd slip or a 31 spline 8.8 w/ posi
  51. 12-18 HP air-cooled
  52. Need a Ranger/Explorer Front Axle D35
  53. 97-01 Xj AC Condensor
  54. Go-carts and Mini-Bikes
  55. ATV's, ATC's or bikes not running
  56. wiring connector for brake prop valve YJ
  57. CJ/YJ Front Clip
  58. yj parts
  59. cb radio plus misc equipment
  60. 3 inches xj coil spacer
  61. Fiberglass one piece front clip
  62. CJ2A Underseat tank
  63. Dana 35 3.55 R&P and carrier
  64. 265/75/R16 or 285/75R16 AS or AT tires..
  65. 2" coil spacers for my ZJ
  66. 93 XJ Front Bumper end caps or whole bumper
  67. tj windshield frame
  68. 2'' lift shackles for xj
  69. 35 inch swamper
  70. xj 3 inch lieaf pack
  71. Motorcycle junk yard off 94 between detroit and port huron
  72. Axles W/ 4.10s
  73. trans
  74. Dana 44 or Ford 8.8 Inch axles
  75. Class C Motor Home
  76. Wanted rear Dana 60 full floater spindles...
  77. 88-96 ranger 4x4 v6 5 spd
  78. WTB black 99 Tj soft top w/1/2 door windows
  79. 1995 4.0 HO Dampner
  80. TF999/727 Inspection Plate?????
  81. silver lake flag
  82. Toyota 4Runner topper '86 vintage
  83. TH350 4x4 tranny working
  84. TJ axles
  85. 1/2 doors that will fit a 79 CJ5
  86. 14 bolt Full Float non-duley 4.10s
  87. metal half doors for TJ
  88. yj windshield frame
  89. zj hood/ d44 lockouts
  90. cj5 best top soft top passnger door.
  91. motor craft carb kit for 4.2/258
  92. 3" leaf packs
  93. Yj mirrors for half doors
  94. WTB: Gears Dana 44
  95. 50-70 gallon fuel tank
  96. uca
  97. 426 Hemi
  98. waggy front leafs sold
  99. 91 pick up
  100. English and spelling lessons
  101. one (1) 315/75R16 tire
  102. Steering column
  103. Someone to hook up a CB radio for me.....
  104. Xj Parts
  105. reg. key for DVD Fab platinum
  106. Tow Hooks for XJ
  107. Winch
  108. Motorcycle
  109. 3.73 or 4.09 gears for amc 20, dana 30
  110. Spare Tire Carrier for a 96 XJ
  111. Riding Mower - Battle Creek Area
  112. 2.5" or 3" Lift springs
  113. looking for a ax15 trans
  114. drive shaft
  115. i need tires or wheels cheap
  116. Trailer Hitch For Tahoe
  117. 37's
  118. WTB grand wagoneer
  119. 16.5 small tires needed
  120. YJ Tail Lights
  121. I need a pair stock cherokee shackles
  122. 8 lug wheels
  123. 5speed,4wd, 2.3 ranger trans
  124. Welder(someone who can weld)
  125. chevy ecm wanted
  126. 00 TJ Automatic FRONT dirveshaft
  127. Dana front 44.
  128. '97 XJ Rear Bumper Corner
  129. XJ Spare Tire Mounting Bracket
  130. need a 4:10R&P for a TJ D35 "AGAIN"
  131. XJ trac bar/equivalent fix
  132. xj fender flares
  133. 16x8-10" 8 lug wheels
  134. orbital valve (SCU)
  135. Great Lakes 4x4 Sticker
  136. aftermarket cd player (car audio)
  137. International Scout
  138. 700r4
  139. 93 zj grand cherokee pcm
  140. Pair of 31 inch M/Ts for 15s
  141. YJ Turn Signal Switch
  142. Need a 93 YJ 2.5 motor
  143. Misc Ford parts
  144. TJ Clutch
  145. 26" mountain bike
  146. Truck cap, short bed Ram 1500
  147. Dalmation puppies (FOUND ONE)
  148. Small enclosed (weatherproof ) trailer
  149. steel wheels (or something cheap)
  150. Chevy 350 throttle body from a TBI
  151. 97 and up XJ rear bumper
  152. Fan Shroud For 2.5L 1994 YJ
  153. ford 8.8 brake stuff and the jeep u-joint adapter/flange
  154. 4.88 gears; ford 8.8 and dana 30
  155. tj rear bumper/ tire carrier
  156. Diamond plate
  157. XJ front end body parts - GOT EM
  158. Needed Dodge Axles
  159. Stock wrangler flares **got some please delete**
  160. 15x8 6 bolt wheels
  161. jeep hyrdaulic release bearing
  162. 258 4.2 motor for jeep, rebuilt or strong runner
  163. Sway Bar Disconnects for a CJ
  164. 33in. M/T's
  165. Stock XJ Tire Carrier
  166. 91-93 dodge ram gas tank
  167. Wanted Narrow track Dana 30
  168. radiator for 1988 jeep cherokee w/ a 4.0
  169. place to buy dune flag
  170. WTB set of ground hawgs
  171. 4 spare tire covers for my rv
  172. Need all shocks for a 2000 TJ to fit a 5.5" lift
  173. Looking for stock TJ
  174. 1st gen s10 gas tank and starter
  175. drop pitman arm 4" TJ
  176. need stock upper/lowerTJ control arms/gotem "plz delete"
  177. Mickey thompson classic II
  178. small block chevy engine slightly used or rebuilt
  179. 31" spare on 15" 5x4.5
  180. Snow Blower, Rotatlier, Lawn Mower, ETC. I need a small engine!!!!!!.
  181. WTB: XJ gas tank skid
  182. TJ hood latches/headlight buckets
  183. GEO tracker rear single seat.
  184. 32s-33s for stock dodge 20" rims
  185. th350 to np231 adapter
  186. WTB: Pool Table Light
  187. (4)265/75/16
  188. seats
  189. weiand stealth intake ford 460/429
  190. kenwood cd player
  191. Tires for S10 215/75/15 or ??
  192. Wanted.....15" 5x5.5" rims
  193. CJ5 Besttop Rear window panel
  194. 99-06 GMC Sierra rear bumper
  195. delete
  196. Rancho Decal.
  197. Chrome H2 wheels wanted!
  198. Cj 5 doors
  199. CJ 7 Drop pitman arm
  200. needed chevy trans/transfer
  201. Amp Wanted
  202. 35 12.50 15 bfg mud terr.
  203. Rear interior liftgate light gray panel 97+ XJ
  204. 220 volt mig
  205. roll bar
  206. grand cherokee front clip parts
  207. s10 /jimmy parts or whole truck
  208. 4.3 motor
  209. WTB YJ Red(PR4) tub
  210. Short box topper wanted
  211. Rams Horn Exhaust Manifolds
  212. WANTED DANA 60's FRONT AND REAR.
  213. trailer
  214. Old ass PDA.
  215. Widetrack rear d44 (or Tacoma rear)
  216. welding
  217. cj or yj that runs and drives
  218. 8.8 or d 44
  219. Wiper Motor drive arm
  220. 96- XJ rear wiper arm - NVM
  221. yj wheel well
  222. Very Inexpensive Dirtbike
  223. 93 yj 4 cylinder motor
  224. 4 inch pocket style flares
  225. gears
  226. place to keep my tools
  227. hummer rims
  228. Waggy parts
  229. A vehicle that runs and drives
  230. xj lift
  231. Wanted: Rear rubicon flares
  232. a cheap project jeep
  233. Folding Chairs and Tables
  234. 16" Rims for CJ7
  235. 33-1250-15 baja claws
  236. Dana 300
  237. 4:10 YJ axles
  238. 94 XJ Front / Rear Tow points
  239. 1990 yj power steering
  240. WANTED -- 44x19.5x16.5 Boggers
  241. Rims and tires for a 98 chevy 2wheel dr.
  242. soft top for a yj
  243. metal lathe around 40in
  244. neutral safety switch
  245. Ranger
  246. I'm looking for a Warn Dealer in the Area......
  247. adapter
  248. WTB 32-33" BFG MTs
  249. YJ/CJ hard top & doors (for trail rig)
  250. Rear Bumper Cover and Gas Door
