- 76 cj5 258 carb
- AMC 360 harmonic balancer
- Spare Jeep 4.0 block.
- J-20 rims
- Need: Radiator for a 97 ZJ 4.0
- Wanted 35-12.50 15 Rim & Tire
- Tires and/or Raider parts
- stock xj or dakota leaf springs or ranger
- D30 CV shafts
- Flexplate for 304/th400
- WANTED :) D30 Limited Slip
- CJ 15x10 5x5.5 rims
- long tube headers for a 302 92 f150
- TJ Front turn signal sockets
- 78-79 f 350 caliper brackets
- Wanted -solid rear wheel openings CJ or YJ
- CJ Dana 30 front axle (3.73)
- 2000 XJ Classic headlight bezel/trim
- transfer case houseing for chevy
- WTB used pair of rocker guards/sliders.
- Looking For Glock 23 .40 Cal
- Folding Tables
- I need a M8274 winch mounting plate./"GOT ONE" thx to all
- ring and pinion
- Wagoneer Springs
- YJ stock front driveshaft
- Rear Dodge Bumper
- 2wd 700r4
- Toyota rear bumper
- Labor
- dana 44's to put under an xj
- cb antenna
- Many new or Like new cj7 parts *needed*
- Need a CJ-7 starter
- 67 mustang fastback title
- 46 rh Trans
- YJ D-shaft and GAUGES
- flowmaster
- WTB 242TC/Passenger Door Panel/30-31" tires/2-3" Lift
- Ford Dana 60 Kingpin
- 2004 Dodge Ram Seat Belt and Driver's Mirror
- WANTED Dodge Diesel 4x4 01-06
- go cart frame
- Looking For, Rear Seat belt, KC lights, winch, tires
- Bronco.. Strong Motor For Dunes !!!
- YJ Safari Top
- dana 20 or parts
- Wanted (2) 15" Grizzly Wheels
- 30 Gal Nat Gas Water Heater
- wrangler starter
- adobe illustrator
- Blower motor for TJ
- 242 T-case
- XJ fuel pump
- Motor and Trans Programer chip for Jeep
- PS2 controller(s) & memory
- wanted biger coils for a 95 ZJ
- dana 44 locker??
- 2 nextel phones
- 1989 XJ Laredo - Need Mechanical Fan Shroud
- WTT my Full Traction 4" ultimate for long arm
- Wanted: Roof Rack for 94 YJ
- dana 44 diff. cover
- Wanted: Ipod Nano at least 2gb or better...
- xj 3" coils
- Spool & gears - Ford 9"
- 50/50 split bench seat
- dana 44 axles
- 3-4" F&R ZJ Coils
- Motorcraft 2100 1.08
- Radiator Fan Shroud
- Chevy NP 203 tcase shifter assembly
- Dipstick!!!!!!!!!!!!!!!!!!!
- zj trans
- Mint Cj Grill
- dana 30 shafts
- TJ pass fender asy + pass tail light asy
- 350 mounts!
- GM Transmission!.
- poly spring bushings
- Automatic Transmission for CJ7
- brush guard
- Front Passenger Fender For A 1991 Chevy Suburban!
- Auto trans for 1990 Tracker
- Need TJ IAC and TPS
- YJ upper doors Spice
- ski doo 670 motor
- need 35 12.50 15 rim an tire
- go kart frame
- A Piece of $hit T-150
- Used lower craftsman tool box
- Looking For A 70 Chevelle
- sales/managment Grand Rapids Area
- Good AX5
- TJ hard doors
- radio wanted
- Wood Stove/ Wood Burner
- who has em' - control arm nuts & bolts
- decent couch
- WTB TJ with 4.0L and air conditioning
- 4x4 truck/suv
- 98 tj wiper motor
- WTB 2wd blazer
- 35 bfg m/t
- heater for CJ or YJ
- NP205 for TH400 or late SM465
- 9.50R16.50LT Tires
- 4-8 lug rims
- Sm465 inspection plate
- 40-18-16.5 Gumbo mudder!!!!
- Xj Extended End Links
- b2 drop brackets
- got one. Thanks "DELETE ME"
- 2 jaw puller need
- Factory Dodge ram wheels 02 and ^ 17" Chrome or Aluminum
- WTB grey center console and mirror for 94 ext cab ranger
- Need a Front TJ,XJ,WJ CV Drive shaft.
- lockers and 33 mud tires
- WTB: D30 with 3.55's
- YJ Ashtray Assembly
- WTB: Need Plastic Valve Cover
- cj sbc headers need asap
- Trade truck tool boxes
- d44 open diff spider gears 3.92 up
- WTB dana 30
- YJ frame + Front glass
- $3k Xj
- lower passenger side control arm perch, dana 30
- TJ Center dash vents
- WTB a Fullsize Truck/subruban/yukon, etc
- WTB 6 on 5.5 rims
- YJ body mount kit
- TJ flares
- Inexpensive Truck Box
- Need xj seats
- rear cherokee springs and/or flowmaster muffler
- 94 ford t-case 1356
- Delete
- Need D30 Shafts
- WTB 36's or 37's
- Please delete
- 38s or 39s 16.5
- 1350 Drive shaft for spare
- 1994 Ford f150 left rear tail light lens
- 7 or 8'' XJ lift coils
- WTB BFG 30x9.50 or 31x10.50
- 35" tires for 16.5 rims
- REAR CJ or YJ Cross member
- 1984 F-150 doors
- WTB: Jeep Scrambler
- TJ Fog lights!!!
- Anyone want to trade roll bars?
- amc 360 dip stick
- Need a FSM
- 1 - 8 bolt rim
- 32" Lcd Tv
- 33-35" tires
- Need an escort engine
- d30 high steer
- tj stock rear bumper, tow hook, third brake light, and tire carrier
- D60 high steer arms
- Clean XJ/ZJ
- Windjammer and Duster deck cover
- '88-98 Chevy short bed, bumper, & topper
- dana 30@35 gears 4.56 or 4.88
- wanted: stock xj front bumper
- dana 44 parts need more stuff added
- spare tire 36-15-15 cepek
- wtb tube chassis or buggy
- TJ fan shroud (for 4.0) *Nevermind*
- '79 ford axles with radius arms
- looking for explorer front drive shaft
- looking for Heim Joints locally
- Spare 35x12.5 tire
- D30 With 3.75 Gears for an XJ
- YJ half doors
- YJ Master Cylinder
- Stereo for Jeep
- need auto tranny for a 94 yj a 32rh
- 700 and + AMP
- T-Bolts and master cylinder CJ
- Ford 8.8 rear axle wanted
- Pitman Arm Gear Nut
- schoolbus wanted
- lower control arms
- 99 4.0 block
- western plow mount for my 04 2500hd
- 97 Ram 1500 Leveling kit
- Trade (or sell) me your 92-95 roll cage for my 91 roll cage
- complete XJ 8.25" 29 spline axle
- found
- Track/Kick Power steering
- WTB: TJ Dana 44 Rear
- Pizza Cutting Tires
- 96 xj drive shaft
- looking for 22RE in MI
- XJ Stock rear leafs
- wanted daily driver car in 600 range.cash in hand
- I'm looking for some steel
- your busted laptop!
- wanted 1994 to 2001 dodge ram chrome rear bumper
- Grand cherokee Dana 35
- wtb chevy 5 bolt rims for an 95 blazer looking for steel wheels
- jeep rims and tires ASAP
- 87-96 Yj Front Axle Needed
- DANA 44 5.38 Gearset & Isuzu D44 Flange Yoke
- Air Compressor/C02 Air Tank
- cap for 8ft bed chevy truck
- Big Hole Dana 18 transfercase
- stock tj front bumper
- wtb mossberg 500 pistol grip stock
- 1994 dodge ram 4x4 Need vacuum pod on front axle
- TJ sport flares
- Wanted--D30 4.10 carrier--- anyone?
- cheap car for senior prank
- zj rear disc brake parts
- 16in wheels
- washer/dryer stacked unit
- 1 H2 rim for spare**Cheap**
- Cj half doors
- cherokee taillights
- want to buy pb gun
- roof rack for my zj
- WTT a 97 tj trans skid for a yj trans skid.
- wanted ford front drive shafts
- Borge Warner T-Case........
- XJ Turn Signal Lenses.
- need a head light and blinker assbly for a 91 ranger..
- looking for a winter beater for everyday!!!
- amc V8 starter bolts
- quadratrac low range shift lever
- Tailgate
- looking for a good 4.2
- Glass topper for 00 GMC shortbox "old"
- Lugnuts for Toyota factory allow rims
- 00 Sonoma wheels
- Eagle 058 16X8 wheel
- Lap Top
- XJ rt side rear view mirror
- looking for tires...stock jeep size and yota size with rims
- reverse 4.10 for d30 and 4.10 for 8.8 ring and pinion
- TJ Fender and flare...
- 36" mower
- looking for a project
- need 2.9L ypip
- a fixer upper dunes toy??
- Yj D35 4.10
- amc automatic tranny
- need carpet for a tj
- ford ac bracket
