  1. 1990 XJ Cherokee TCU
  2. TJ rubicon fender flares
  3. need pair of nice 12-14" shocks w/ rez
  4. 5.12 Tracker front third
  5. TJ Rubicon front springs
  6. fj60 or fj62
  7. S blazer tailgate
  8. Redrilling axle shafts
  9. Silverado Transfer Case
  10. WTB TJ Carpet and Trim under the steering wheel
  11. Track bar & driveshaft for a 1997 TJ
  12. 97-01 Cherokee flare brackets
  13. tubing bender
  14. Wanted early bronco rear axle
  15. 4x4 Sb c6 trans
  16. xj wheels
  17. superduty bed and tailgate
  18. 35 spline dana 60 locker
  19. *** GM 6.0L Engine 4l60 Trans ***
  20. looking for 97 wrangler 2.5 engine, 97+ era
  21. Used camper tires
  22. fridge and electric stove
  23. 5 x 4.75 aluminum wheels 15 inch
  24. TJ Half Doors
  25. Jeep jk - doors
  26. XJ 91-95 throttle body 4.0L Midland, MI area
  27. Wagoneer Driver Drop Front Axle
  28. 33x15" tires - prefer MT's
  29. running vortec 350
  30. d300 clocking ring
  31. Zf 5 for power stroke
  32. Dana HP 30 XJ or TJ
  33. WTB: 4.0l engine for 01' Jeep TJ
  34. TJ 4" Longarm kit and 33" M/T's
  35. WTB, Locker for 8.8 lunch box style
  36. Looking for a boat trailer for a 18' open bow Thompson
  37. Wtb xj 4.5-6.5 lift coils
  38. Looking for 33/1250r17
  39. WTB 37x13.50 15 at least one
  40. 99 and up f350 or 250 short box
  41. Need 14bff open dif
  42. Stock yj shackles
  43. Couple 5x4.5 rollers
  44. Mandrel bent front half jeep frame rails wtt for straight tube
  45. YJ 3/4" boomerang shackles
  46. 1x h2 aluminum wheel
  47. 1410 yokes
  48. Junk 4.0 crankshaft
  49. Wanted: inch lb beam style torque wrench
  50. WTB: Gray headliner for 97-01 Cherokee (XJ)
  51. Mile Marker 426 hubs
  52. Small pull behind trailer or just an axle.......Changed Plan
  53. tires for 16 in rim
  54. K5 blazer tailgate
  55. Cap ford f150
  56. Wanted-ZJ rear track bar bracket
  57. 1.25 tube bungs
  58. 40" tires
  59. Stock JK front track bar
  60. grand cherokee tansmisson
  61. kia motor
  62. D44a axle shafts.
  63. Rooftop Cargo Basket
  64. Ford F250 Short Box
  65. Tires
  66. 30 gallon plastic barrels
  67. Wanted 99 TJ Dash Harness
  68. WTB ford d44 parts
  69. ISO 95' 4.0 5spd. ax15 trans?
  70. tig welding near hartland howell fenton
  71. WTB JK Front Control Arms and Track Bar
  72. Anybody have a bobcat they would like to rent for a weekend?
  73. Black TJ Duster
  74. kids motocross boots
  75. stock tj pitman arm
  76. WTB Tj tailgate bar for a soft top
  77. 20"-23" Rear Drive Shaft for CJ5
  78. 460 big block ford
  79. 15 x 8 GM 6 lug Steel Wheels
  80. 15x8 6 lug steelies
  81. 14" coilovers need 2
  82. Yj seats and center console
  83. Compressor motor needed
  84. GM/Chevy TBI 350 stand alone harness.
  85. PCM tune 4.8 to 6.0 swap
  86. Tj soft top and soft uppers
  87. iso good front seatbelts for wrangler
  88. Wheels and tires for Jeep Wrangler YJ near OEM size
  89. Factory Rear Blocks for a F-350
  90. 225-60-15 need 2-4
  91. cheap pair of thornbirds 29x10-15
  92. looking for 17" superduty rims
  93. 33x12.5x15 truxus sts
  94. Toyota solid front axle
  95. Chevy 6-8" lift springs
  96. Chrysler 3.8 v-6
  97. Wanted: 38/16/ super swampers (2)
  98. Truggy Project
  99. Rear driveshaft 52" slip shaft
  100. stock tj seat braclets & 32rh
  101. ISO: Car Trailer/Hauler
  102. 4x6 ft Sheet of ??? for small trailer deck
  103. In need of a distributer
  104. 96 jeep need fuel tank for it
  105. 2.5 exhaust manifold
  106. YJ drivers side fender
  107. 03 s10 crew cab- NEED NEW BED!
  108. Explorer Driveshaft Or Rear Yoke
  109. One spare 33x12.50x15
  110. YJ stock rear leaf showings and bushings
  111. mid 90s chevy 350 power steering pulley stuck at blessing
  112. DANA 30 SYE REAR YOLK- @ Blessing
  113. Need a d35 axle shaft! In mt pleasant now.
  114. YJ Skid Plate and Tailgate
  115. food cart
  116. 2000 cherokee 4in or 4.5in rear lift leafs
  117. Dana 30 Locker
  118. Looking for 95 grand Cherokee Oem bumpers
  119. Wanted cheap bbq grille
  120. a nice patio set
  121. 1 or 2 BFGoodrich All Terrain 235/75/15
  122. Thunder AVS carb 650 electric choke
  123. Looking for t5 s10 2wd
  124. Sbf C6 3000 stall
  125. 1999-2006 GM 1500 2" hitch
  126. dana 44 axle shaft (front)
  127. 99-06 Gm 1500 leaf springs
  128. D60 Kingpin Caliper Bracket/s
  129. Wanted: four 33-37" tires for 16" wheel
  130. WTB: Ford 302/351 Heads
  131. cheap 350
  132. wtb (2 or 4 ) wheels 5 on 4.5 jeep.
  133. toyota calipers and lock outs
  134. Soft top for 91 YJ
  135. 2000 TJ Trans & Tcase
  136. S10 bed, NEED ONE
  137. Trailer Use for May 9-11th
  138. Dana 70u hub.
  139. wtb treadmill
  140. 40 or 44 series flowmaster
  141. Barn find
  142. Toyota parts
  143. Tj doors
  144. WTB 35" tires
  145. 1999 Grand Cherokee parts.
  146. Wanted 33 12.50 r16
  147. Bobcat work?
  148. wtb dana 30 with 4.10
  149. WTB 4.0 Engine
  150. Chains and binders
  151. tj air box
  152. yj rear seat
  153. JK front axle, windshield frame, tailgate, top, & full doors
  154. KC or HELLA off road Light housings
  155. 1 stock xj shackle
  156. track bar for 99 xj Cherokee
  157. 1 1/2"x1/4" wall DOM
  158. Looking for rear drive shaft
  159. Tj wheels, tires, lift!
  160. In search of headers for 1990 bronco with 460
  161. looking for chevy rear lift springs
  162. Steering box
  163. WTB: ZJ front shocks
  164. Nv244 t-case for dodge Dakota
  165. 8 lug 37's or 38's
  166. Plumber
  167. wtb Dana 35 4.10gears yj
  168. WTB 205 or 215/75/R15 tires mounted on 5x4.5 wheels (stock jeep sizes)
  169. WJ 4.0 Motor
  170. set of 16" rims 5 on 4.5 with a good negative offset. I do not care about blemishes.
  171. 16'-18' car trailer
  172. WTT - 16" GM 8 lug rollers for 17" GM 8 lug wheels/rollers
  173. HP Dana 30 and Ford 8.8
  174. 454 intake
  175. 37s or 38s
  176. Wtb jeep parts
  177. 14.5/ 19p mercruiser prop
  178. 1999 Jeep Grand Cherokee Headlight
  179. Light housing
  180. XJ and ZJ parts
  181. TJ 3:73 dana 35 rear axle
  182. Toyota lock outs for an 85 4runner.
  183. Black tj hard top
  184. XJ drivers glass
  185. looking for jeep tj rubicon factory wheels
  186. Front Seats for 97 TJ
  187. I'm looking for used wakeboard tower speakers.
  188. WANTED - TJ Front/Rear Bumper, Tube Fenders & Winch
  189. S10 Blazer Roll Cage--- no longer need---
  190. 14/36.5-15LT Grand Prix 4 Wheeler RVT/Ground Hawgs & 15x10 6 lug GM Wheels
  191. 15x10 rims 5x4.5 bolt pattern
  192. Rear end
  193. 35" R18 mud terrain tires
  194. dually axles with 3.55 ratio for 95 Ford
  195. Tj entry steps
  196. Someone to split wood
  197. YJ or TJ with 6 cylinder engine and manual trans
  198. WTT full size doors Please *DELETE*
  199. XJ Front end parts
  200. Transmission Rebuild
  201. WTB YJ front driveshaft
  202. Lift coils for '96 f150
  203. 33 Spare wanted. Have nice 31 to trade or cash
  204. 33-35x12.5r17
  205. wtb 5x4.5 x1.5 thick wheel spacers jeep. 2 or 4
  206. wanted - 91-98 jeep xj
  207. Front driveshaft for 2003 tj w/5spd
  208. 231 transfercase for 97xj
  209. Looking for a Tubular GT40 upper intake and a lightning lower
  210. '98 Engine Harness from 4.0 TJ
  211. 205 tcase adapter plate
  212. Np205 adaptor for turbo 350
  213. 99-03 ford f150 super crew running boards
  214. 455 olds
  215. 17" gmc 6 lug alloys
  216. YJ seatbelt
  217. th350 parts
  218. 16.5 5x5.5
  219. WTB, 315 or 325 70 17s
  220. Yj rear seat belts
  221. XJ rear springs
  222. Wtb 1.0 id dom
  223. Wanted: Square Body Chevy Fender
  224. 14 Bolt 6 Lug 3.73
  225. tcase rebuild
  226. wanted: tracker/sidekick trail rig 1k$
  227. Ford 292 or 312 engine
  228. C6 shifter
  229. Wanted- 17" Mickey Thompson Classic ll
  230. 5th wheel hitch
  231. Wanted 35" spare on 15x5x4.5 rim
  232. Silver lake voucher for Sunday
  233. Cb antenna connector
  234. s10 manual doors that fit an 86 regular cab
  235. xj parts
  236. ford np203
  237. samurai lift parts//add ons.
  238. Wanted.. Dodge king pin dana 60 complete
  239. WANTED 17 " 6 lug wheels
  240. AMC 360 Flywheel Needed.
  241. ISO TJ driveshaft
  242. yj half doors
  243. HP 30 with 4.10 gears
  244. air shears to cut some aluminum
  245. One big ass MT for tire swing
  246. $400,000 casino cash for a used XJ trac-bar
  247. Dana 60 1310 Yoke Needed
  248. 97+ XJ Manual Shifter Boot and Bezel
  249. 15x8 5 on 4.5 black wagon wheels for tj
  250. 05 tj skid plate
