  1. Big Block Chevy Engine
  2. xj front drive shaft
  3. 4cyl HEI distributor
  4. YJ bumpers
  5. looking for 14.9R24 tractor tires
  6. ford 9" housing
  7. WTB/ snowblade 90 ranger !
  8. Minibike/3wheeler wanted, or two?
  9. 33-37ish for 16 or 16.5 wheel or other rim size if 8x6.5 bp
  10. Wtb 35/12.5r16.5 bfg mt old style
  11. 1st gen dodge hitch
  12. Looking for a complete full hydro kit and aftermarket tbi
  13. Wanted Dead or alive! a 1969 Camaro project
  14. Hitch for 95 Chevy 1500
  15. Need 4.0 head 0630
  16. Superduty 4 inch(ish) lift kit/stuffs wanted
  17. 97 TJ 4.0L Auto PCM
  18. 16" beadlocked rims
  19. drill and tap 2.5 inch aluminum bars for me?
  20. Lookin for f250 4x4 rear drive shaft.
  21. np205 10 spline input
  22. Wtb 95 jeep cherokee 4.0 5 speed pcm
  23. NP231 23 Spline Input Gear
  24. Jk Dana 30
  25. Jeep tj or chevy 350
  26. Looking / stock SB Chevy valve covers
  27. 285/75/r16's needed!
  28. 350 chevy
  29. 5x5.5 rim
  30. Wanted: set of 16" tires
  31. Reliable vehicle $2500 any condition
  32. 8.25 rear axle
  33. KRC pump pulley
  34. 90-94 xj wanted
  35. looking for dana 30 hubs and spindles
  36. 98 tj ECM
  37. Wanted 3.73 ring and pinion for dana 30
  38. Wanted 33s or 35s for lifted '06 F150
  39. Looking for 97-01 Jeep Cherokee (XJ) stock fender flares
  40. looking for 16.5 steel wheels
  41. wanted: 14" and/or 16" coilovers
  42. Steering gear box 04 wrangler
  43. 3" lift shocks for a zj
  44. Wanted 7.3 powerstroke superduty
  45. 37s or 38s need some cheap
  46. TJ soft top frame.
  47. Wtb d30
  48. 8.25 29 spline limited slip or locker
  49. Tires: 31" or 33"
  50. 7.3 idi (pre powerstroke)
  51. Car shopping
  52. Hp d30
  53. Wanted NP242 for ZJ
  54. Old steel pedal car
  55. 00 cherokee parts
  56. WTB: Stock TJ carpet in good condition
  57. NEED ASAP!!! XJ Stock trac bar mount
  58. wtb dodge d60 front housing with CAD
  59. need a yj dana 35 with 3.07 gears
  60. Full size truck roll bar
  61. Good set of 245/70R16-Delete
  62. 2005 tj drivers side mirror
  63. Pellet stove 1000.00 or less near howard city.
  64. Buddy looking for set of tires for F 250 diesel
  65. Set of TJ fenders and Sahara/Rubicon flares
  66. 1997 F150 fuse box.
  67. black zj hood
  68. TJ parts
  69. toyota doubler wanted
  70. exhaust fabricator
  71. wtb silver
  72. wtb Dodge Ram Running boards
  73. DONE - Black Friday/Thanksgiving Deals on Rubicon 4.88/5.13 gears - DELETE
  74. Yj Seat belt,aftermarket bumpers and sliders
  75. TV Antenna Tower - Cheap
  76. Great Lakes 4-wheel drive center: Grand Rapids info
  77. Dana 44 hp 4.10 gear set
  78. 2.0 air shocks 12 14 16
  79. 7.4L tuner or chip
  80. 4.10 or 4.56 ring & pinion for a Ford 8.8.
  81. Wanted ASAP 15in 8lug rims
  82. Wanted 18" tires 275/65-18 or 255/70-18
  83. Indoor storage for vehicle
  84. WTB: E4OD Trans. or Torque Converter
  85. WTB yj lift and any aftermarket parts,bumpers etc....
  86. Wanted: 6x4.5 rims
  87. Heater Panel (interior)
  88. Wanted xbox 360
  89. Looking for 33-35 inch tires for 16 inch rim
  90. winch wanted
  91. Wanted '03-'07 Vue Silver Left Front fender
  92. wtb TJ front drive shaft.
  93. 17" WJ or JK wheel(s)
  94. WTB 31x10.5x15 1 or more tires .
  95. looking for a 2000 dodge ram wheel.
  96. New Wrangler Wheels
  97. Wtb d44 carrier
  98. 36/37 for 16.5 rim or bigger need them cheap
  99. 18in 8 lug rims need 4
  100. Dodge nv4500 from cummins or v10 4x4
  101. trade my 32" mt tires for 33" at or mt
  102. TTR 50 parts
  103. Tires 225/70/16
  104. xj complete long arm set up for front
  105. hp 30 axle shafts
  106. I need an air cooled Volkswagen engine guy.
  107. YJ or Xh stock air box
  108. jk front axle
  109. WTB: External Generator Enclosure
  110. 1st Gen S-10 Fan Shroud
  111. Steel drum 30-55gal
  112. Auto steering column for yj
  113. rubber, 255 70 16r
  114. Driver Side Mirror (TJ)
  115. 99 dodge 4x4 auto trans 46RE
  116. Wanted ASAP ZJ V8 power steering pump 1995
  117. 4x4 Chevy Suburban Wanted
  118. WTB Chrysler 8.25
  119. trailer
  120. 16" rims with 5-5.5 bp
  121. 88-99 OBS Chevy 3/4 ton torsion bars
  122. Wanted: 1993 F350 Front Driveshaft
  123. SBF Headers
  124. Reliable vehicle under $3000
  125. ford 9in center section
  126. Wtb 245/75/16's
  127. 16" winter beater tires needed!
  128. TJ Exhaust
  129. Jeep TJ/ LJ soft top pivots
  130. Wanted: XJ/WJ/TJ/ZJ/MJ Project!
  131. Wanted: air compressor pump or rebuild
  132. 98 TJ Alternator
  133. gas station style air pump
  134. wj front brake calipers
  135. D60 Rear Shafts----GOT WHAT I NEED
  136. 27 spline input for np 205
  137. Looking for a tractor
  138. 10# co2 Tank
  139. 1996 zj 16" gold aluminum rim
  140. need 35x12.50x35 tire
  141. 92-96 ford D60 knuckles, stubs, and hubs
  142. mobile home tires
  143. 44 tsl
  144. Dana 30 4:10 gears
  145. abs speed sensor ASAP
  146. Ice tires dirt bike
  147. ATV plow and winch
  148. wtb k5 blazer or jimmy
  149. 1997 Sonoma 15" tires and Aftermarket S10 parts *Small Truck Roll Bar*
  150. Early xj renix efi gas tank
  151. 17" 8-lug Beadlocks, 1 or 2
  152. tj front driveshaft
  153. pewter/tan colored hood for 2000 chevy
  154. Wtb 33/12.5r16.5 bfg at
  155. TJ passenger front seatbellt
  156. Radiator 03 TJ
  157. Jeep 4.0 fan blade
  158. Looking for 16/17 in 8lug wheels
  159. Chest or standup freezer
  160. 2x4 and 2x2 3/16 steel tubing
  161. Wtb: Jeep TJ Fenders/ Flat Fenders
  162. AX15 and all parts needed to swap in to 2000 XJ. Other XJ parts.
  163. JK License Plate Holder
  164. Need some tools
  165. BA10 for 87 YJ
  166. 35s or bigger wanted for 16" or 16.5" wheels
  167. Wanted someone with a Lathe
  168. Wanted Dodge np205 Tcase
  169. WTB Samurai Front axle
  170. 36x15 swamper
  171. dually rims
  172. Toyota mini truck rear springs
  173. YJ Top - Hard or Soft ;) Prefer Black
  174. wtb xj rear drive shaft
  175. turbo 400, np 205, super duty d-shaft, camaro manifolds
  176. looking for "D"window steelies for 95 XJ
  177. 2000/2001 4.0 Xj shortblock
  178. 99 tj 4.0 auto Ecu
  179. Dana 60 Carrier spacer
  180. Ford cab, rollers, doors, etc.
  181. High end high flow fuel pump for a carb
  182. Scorpion bbf 1.73 roller rockers
  183. Art Carr c6 shifter
  184. 2 16" 2.5 coil overs
  185. Bbf c6 with a 208
  186. Art Carr Shifter
  187. Front d60 32 spline locker
  188. Wtb 2 sway away 14" bypass shocks
  189. xj control arm drop brackets
  190. xj - adjustable track bar and drop bracket 4.5 - 6 inch lift
  191. xj - drop pitman arm for a 4.5 - 6 inch lift
  192. Chevy np205
  193. 97 f250 powerstroke parts
  194. HP D30 Non-disco w/4.10s
  195. Need 245-75-16 tires
  196. 3to6 in lift for my 99 superduty
  197. V8 Ranger
  198. 231c s10 t-case
  199. Lifted toyota or Nissan 4x4..must be reliable on a daily basis
  200. TJ inner fenders
  201. 2.5 ton front rockwell parts
  202. 03-06 Automatic Rubicon front driveshaft PLEASE REMOVE
  203. Chrysler 8.25 for XJ
  204. Buick Dauntless V6
  205. Exhaust parts for ford explorer.
  206. Front and rear bumper upgrade for a 96 XJ Cherokee project
  207. JK 2010. Safari or bikini top wanted
  208. WTB 2.2 ecotec for a 2003 cavalier
  209. roof rack basket
  210. Wanted Th400/np205 combo
  211. Wanted Th400/np205 combo
  212. Dodge 3.55?
  213. 8x10 trailer wanted
  214. trade my RZR 800 for your 50-70 hp tractor with loader
  215. 55 gallon drum
  216. Wanted... 80 or 90cc youth quad.
  217. 2012 focus wheels / tires
  218. 2013 2500 chevy hd stock steel wheels
  219. Ranger dipstick tube
  220. tj 2.5 overflow bottle and column with key may also be looking for tube fenders
  221. Snow PLOw
  222. 1999 4.3 vortec motor
  223. :Wanted: One ton axles
  224. 1999 stock 6 lug chevy rims
  225. craftsman snow plow
  226. s10 leafs and jk shocks
  227. 16.9 - 26" tractor tires.
  228. CJ7 spare tire carrier/ rack
  229. dana 35 locker or open carrier for 3:54 and numerically higher
  230. WTB(saginaw): Jeep TJ top and doors.
  231. any 265/16's laying around
  232. Jeep Dana 30 LP gears 4:10
  233. Jeep xj dana 30 locker
  234. any 265/16's laying around
  235. YJ windshield frame
  236. Jeep CJ Axles
  237. 2000 XJ Motor
  238. 1999+ Ford F350 Dually Wheels (8 x 170mm) & front DRW spacers
  239. WTB snowex vbox spreader
  240. NEED tbi 350
  241. I need a working AX15.
  242. 9 inch third
  243. xj/zj lift parts
  244. j 10 y pipe
  245. Trailer tires
  246. Wanted Dodge 47RH!!
  247. Wanted At&t smart phone that works
  248. rear axle for 94 chevy
  249. 14 bolt locked and 4.10 geared
  250. Ice Fishing Equipment
