  1. 14.9/26 rimz
  2. wanted 33's
  3. 38-42 inch tires wanted
  4. Jeep liberty front fender flares
  5. Dodge np241 form 5 speed
  6. Toyota tailgate
  7. 68-72 chevy truck box
  8. chevy np208 shifter
  9. Rear Dana 35 disc brake brackets wanted.
  10. Wanted Cheap/Free 6 lugs with or without tires
  11. Looking for a (running) pretty built sbc 350 or larger...
  12. TJ Gas Tank Skid
  13. Not needed anymore
  14. steel decked car hauler
  15. xj susp parts wanted
  16. WTB/WTT ford axles HP44-9"
  17. 96-98 chevy 1500 ext cab lookin for one that needs a motor or trans
  18. WTB: Honda Elite 50cc 94-01
  19. TH 400 Inspection cover
  20. wanted 1979 f350 crossmember
  21. 1992-1993 Explorer 8.8
  22. ZJ Seats, Ravine wheels, XJ LCA adj.
  23. Wtb 3.73 gear sets for dana 60 front and 14b ff rear
  24. WTB: 38-42 inch mud tires, 20 inch wheel size..
  25. 4 door explorer leaf springs
  26. dodge 360 complete motor
  27. 2- D30 stub shafts(wheel bearing ends) with nuts
  28. Soft Doors
  29. Ford Lift Coils
  30. 1tons for a second gen Ram
  31. WTT: 80's kingpin ford 60 for 78-79 ford 60 or chevy 60
  32. NEED ONE 31 10.50 15r TODAY ONLY ONE NEEDED!!!!!!!TODAY
  33. Demo/Construction guys in NE Michigan
  34. Stock 78-79 Ford 60 inner axle shafts.
  35. Wanted Dana 35 TTB
  36. 6 lug chevy rims aftermarket
  37. 318 heads or complete motor
  38. need to 32/?/15s
  39. amc 360
  40. 1 rim - 17x8 or 17x9 - YJ/XJ/TJ Bolt Pattern (5 on 4.5)
  41. Chevy 10b/d44 crossover steering
  42. Light duty trailer axle
  43. looking for a starter bike
  44. Looking for some 17" or 16.5" 8 lug rims
  45. Chevy TBI 305 heads
  46. Rockwell axles
  47. Heavy Duty Dodge Ram Bumpers
  48. WTB seats for my jeep
  49. WTB winch 6000lb + asap
  50. wtb a full set of 15 x 12" or 14" wide 8 lug wheels
  51. REAR Axle 1998 chevy 1500 4x4
  52. PCM for a TJ 4.0 stick
  53. topper/tonneau cover clamps
  54. 37"-40" radials
  55. wtb 2 post lift
  56. wtb carbed 351w
  57. 01 grand cherokee drivers seatbelt
  58. gears for dana 30hp and chrysler 8.25
  59. vortec 454 intake.
  60. looking for a toyota front axle
  61. 35 mt's
  62. 1996 xj cps
  63. 6.0 ICP sensor and MAP sensor
  64. Diesel zero turn mower
  65. Need psd coresupport
  66. Th400
  67. xj shocks
  68. tj fender flares
  69. WTB: 1994 4l60 4x4
  70. WTB: tbi 305 heads
  71. Wtb truck
  72. Chrysler 8.25 29spline carrier
  73. WTB HP Dana30 housing
  74. Needed tires tonight
  75. wanted: garage or barn to rent in Goshen
  76. 88-98 chevy bench seat-burgandy
  77. WTB 4.0 straight six
  78. tj axle shafts
  79. WTT wheels and tires
  80. WANTED: Verizon cell phone (NOT a smart phone)
  81. wtb or wtt i need a 231 tc
  82. Looking for a set of tires
  83. VW Bus 091 trans (6 rib) 4 speed
  84. 20 foot elevator
  85. Soft top
  86. WTB Jeep TJ/LJ
  87. TJ Roller/smashed/blown up
  88. read this please, need a lead on a cheap old jeep
  89. WTB 15 x 8 Jeep Rims (5X4.5)
  90. WTB: zj rear axle 3.73
  91. looking for oem radio for my 04 silverado
  92. zj or tj rear disc for dana 35
  93. Stock 2004-2008 F150 Rims
  94. wtb: jeep xj front winch bumper
  95. Wanted nv3500 with241c transfer
  96. Wanted a 6inch suspension lift kit 04 z71
  97. 73-79 ford f 150 9 inch lift coil springs
  98. wanted dana 44 high pinion axle leaf-spring 4:10 gear
  99. 14 bolt yoke 1410
  100. wtb michelin XML 325 85r16 tires.
  101. oops
  102. looking for 38"-42" tires
  103. Prerunner/dune truck
  104. 81-87 rust free chevy hood
  105. Trade sprint iPhone 4S for GSIII or similar
  106. 35'x12.5x15 tires
  107. Jeep cherokee parts wanted
  108. Wanted 7'x14' enclosed trailer
  109. 4.10 Ring and Pinion for Chrysler 8.25
  110. gas tank
  111. land contract home wanted
  112. Need a factory radio for a 2002 tj
  113. Wrangler tj hitch receiver
  114. 33" Mickey Thompson baja MTZ
  115. looking for sbc 1 pcs rear seal flywheel
  116. want to borrow a tj,yj,cj corner guard
  117. WTB/WTT for 2.5 or 5 Ton 6x6
  118. exhaust -cats - 2004 LJ
  119. stock h1 wheels and tires
  120. 1997 XJ Battery Hold Down
  121. F150 parts
  122. WTB (2) 33x12.50x15 bfg a/t
  123. 99- 02 Dodge ram sport front bumper
  124. Good car for a kid
  125. wtb decent set of 32/33 or 205/305 for 16'' rims
  126. pair of 245/75r16's
  127. Wanted a 6in suspension lift for 04chevy
  128. Xj lift... Something over 4"
  129. need starter for a 5.3 motor, and...
  130. Looking for a Cummins 6bt with manual trans OR a just a ZF6 trans from a 7.3 PS.
  131. cylinder heads for a 4.7l j motor
  132. Inexpensive Utility Quad
  133. Cheap 4 wheeler or 3 wheeler putting on hold plz delete
  134. Geo Tracker Hood
  135. 8x6.5 wheels wanted
  136. steel tubing needed
  137. Wheels for paddles chev 6 lug
  138. Grand cherokee brake parts wanted
  139. Jeep 2.5L engine
  140. WTB Chevy 6 bolt rear end
  141. Need a 95 Toyota t100 rear axel thinks its a 410i
  142. tj dana 30 locker
  143. looking for rider !
  144. Dana 60 SPicer lockouts !!!!!!!!need today
  145. Want to trade my CJ7 Hard top/full doors for nice Soft top/soft doors
  146. 2 33/12,50/15 sidewinder or something of the same treat 50% or more
  147. 93 XJ pieces
  148. chevy water pump bolt?
  149. late 70s dana 30 w/ disc brakes
  150. 6.0 lq4 lq9or built 5.3
  151. 8.8 with 4.10
  152. Roll bar wanted !!!!!
  153. WTB 20" Silverado Wheels and tires
  154. 14 bolt U bolt plates for chevy rear axle
  155. Re end and drive shaft dodge
  156. Repairable VW Etc.
  157. steel sticks or tube
  158. wtb 16.5 x 10 or 9 rims need 6 of them
  159. 305/350 vortec
  160. WANTED old 37 12.50 15 MTR ONLY ONE
  161. Looking for a car
  162. looking for nice 93 dodge ram bed
  163. WTB alloy USA axle tube seals
  164. 94+ ford 10.25 yoke
  165. Solid 6 Cylinder YJ Frame
  166. XJ Seatbelt
  167. Front TJ Rubicon 44 axle shafts
  168. Posted in wrong area DELETE
  169. 98 dodge **axle 3.90**
  170. tj passenger soft upper door or repair shop
  171. 92-96 XJ Engine and trans and harnesses
  172. looking for a flowmaster or someother aftermarket muffler around lansing mi
  173. Jeep Liberty Freedom Edition wheels.
  174. NICE truck or suburban
  175. 1410 drive shaft non cv - NOW 1350 CV shaft :)
  176. xj header panel / headlights
  177. tracker at tires
  178. 2001 TJ vacuum pigtail for HVAc panel with A/C
  179. Wanted 77-78 dodge grille and tailgate
  180. 89 bronco 2 fuel sending unit
  181. tj rear adjustable control arms
  182. looking for 33s
  183. TJ 3 speed auto BAD transmission 32RH or one part from it.
  184. looking for 1 or 2 35 12.5 15s
  185. wtb power steering pump for A 96 grand cherokee
  186. 304 exhaust manifolds or headers
  187. 44s
  188. 1 bfg at 31/10.50/15 need asap 50% or better
  189. wtb:(4) 35 or 36 or 37 x12.5(ish)x16.5 tires only.
  190. 4 - 235/75r15 or 30x9.5r15. A/T or M/T
  191. Shifter handle and knob for ZF6 transmission
  192. Bart 15" 8 on 6.5
  193. 1st Gen 4runner Tailgate
  194. mini buggy or something like a honda odyssey. maybe frame or rollers
  195. honda 300ex exhaust
  196. Hei distributor
  197. 35 or 36 tires on 6 lug wheels good tread
  198. Chevy/FSJ Spindles 73-76'
  199. tool box
  200. Tj Dana 30 4.10s
  201. 4.0L Good Runner
  202. 258 frame mounts
  203. 80-86 ford long box
  204. jeep tj door latch
  205. ISO- Car Trailer
  206. 1- 15x8 5x4.5 rim
  207. Concrete or big rocks
  208. gm spare tire mount
  209. 5x4.5 16" steel wheels
  210. Looking for a C-4 Bell housing
  211. Super duty back window
  212. small boat and trailer
  213. 5:13 gears
  214. WTB: Cherry Picker...
  215. ford cab visor
  216. Need: Complete pair TJ axles
  217. wtb 31x10.5x15s
  218. Silverstone Metallic 00/01 Cherokee WANTED
  219. Boat Trailer Tires
  220. TJ Axles
  221. Rubicon front axle
  222. Cheap beater. Yj xj ranger explorer bronco 2
  223. 1979 Ford monster truck
  224. driveshaft
  225. Welder or welding needed- axle conversion
  226. WANTED 265 70 R 16 TWO at least 70% tread
  227. chevy front axle
  228. Wanted: YJ SOFTOP and frame
  229. wrb cheap hi lift jack
  230. wanted: jeep fuel filler neck
  231. YJ door uppers
  232. Looking for one 37 and H2 rim.
  233. Some sheet steel
  234. 1993 ford f 450 dually axle
  235. wanted junk ax5
  236. AX15 bellhousing or complete trans
  237. LSx Set Up!!!
  238. 4wd truck(super cab or crew cab) or mid to full size suv
  239. Ford explorer
  240. yj tub
  241. Rear seat for Suzuki Samurai any condition
  242. no longer needed
  243. teraflex 2 low
  244. 90cc Quad rent/buy
  245. Cage for a blazer
  246. novak cable shifter
  247. Looking for a 99-07 Silverado or Sierra short box
  248. 5 on 5.5 rollers
  249. 99-2006 silverado / sierra tcase push button
  250. WTB lift for 97 dodge 1500 sport
