  1. 4x4 4l80E
  2. Verizion Droid 2 Global
  3. gm 14 bolt ff 4.56 gears.
  4. 2 front xj shafts/ doner shafts
  5. Drivers side xj mirror
  6. 5 on 4.5 wheel spacers
  7. Dick Cepek FCII
  8. Semi wheels, 19.5X7.5, 22.5X14, 2 Each
  9. 80s chevy
  10. Jk Dana 44 gear install around grand rapids.
  11. WTB: Intake manifold for chevy 4.3 V6 for 01 Trailblazer - ASAP!!!
  12. Dana 44 Full Spool
  13. t case for a 00-01 grand with a 6 cyl
  14. chevy 205
  15. YJ front leaf springs
  16. 06 YFZ 450 FMF Slip on exhaust
  17. Chevy 6 lug rims
  18. 14 bolt 10.5 4.10 down carrier
  19. alternator bracket, TJ, 4cyl.
  20. Dana 44
  21. cheap xbox games
  22. wtb: yfz 450 stock front shocks
  23. tj hood lactch
  24. cummins 4cyl
  25. Bw1350
  26. Chest style toolbox
  27. Need A TJ Dana 30 Housing
  28. k5 roll bar
  29. WJ Tow hooks
  30. Fuel cell..used or good place to buy new.
  31. wtb parts for 06 dodge ram
  32. Good Spare tire
  33. Rustfree 2003 Ford F-250 front doors
  34. adapter plate
  35. M/T Sidebiter's 15x8 for TJ
  36. wanted drivers side fender and grille for 2000 tj
  37. looking for a factory tj soft top and hardware
  38. Bestop Instatrunk Storage
  39. 35/12.50r15 bfg at
  40. Dana 30
  41. 1310 driveshaft
  42. BW1354 Shift Lever
  43. XJ 4.0 Renix parts
  44. tj rubicon oem diff cover
  45. need! 00 wj 4.0 in good running condition
  46. WTB - 36x12.50r15 TSL's
  47. Ram Tow Hooks
  48. Tacoma Parts - Axle and/or transmission
  49. ATT Smart phone
  50. Looking for a train horn
  51. 1.6 roller rockers sbf pedestall mount
  52. d30 steering knuckles
  53. d30&ch8.25 4.10gears
  54. Looking to lift Xj Need Whatever you wanna sell
  55. i need two 235/75/15's street tread
  56. e4od for a 96 f250 diesel
  57. looking for wheels, 15x10
  58. Looking for 1980's-90's Ford Dana 60 front axle with parts needed for F250 install
  59. 42re Wanted
  60. TJ brake booster
  61. '90 Dakota v6
  62. Certified welder person
  63. 245/75/16 tires
  64. Grand Cherokee Cloth Seat Set - Charcoal
  65. need a radiator
  66. 78-79 Ford Bronco Top Black
  67. Need fuel cell!!!!!!!
  68. Chevrolet truck vent window
  69. 99-07 8' Chevy Truck Topper/Cap
  70. Metal lathe
  71. looking for a good aw4 trans and stock TJ suspension
  72. buick 425 nailhead
  73. can someone build a xj 2-2.5inch bastard pack under 200?
  74. tj drivers seat **FOUND**
  75. Looking for a large off road tire
  76. TJ Front Coil Isolators
  77. Look for a GOOD set of 15" 33's
  78. BBC Crank pully
  79. ford 460 rear sump oil pan
  80. looking for a 4bt cummins motor
  81. Chevy or gmc tail gate asap
  82. Looking for a starter
  83. WTB tonneau for 8 ft bed 88-98 gmc/chevy truck
  84. c4 trans, 70 up
  85. junk johnny joints or something similar
  86. Distrubution Hitch ***LOCATED!!!***
  87. Looking for 4.10's or 4.56's For a Ford
  88. 4x4 toy
  89. 35-37" mud tires wanted
  90. RBV doubler
  91. WTB: Family Wheeler project
  92. 16" 5 on 5.5" wheels
  93. Rims and or tires
  94. Metal tractor seat
  95. want sm465 to 205 measurement
  96. wtb 35"x10.5"x15" boggers
  97. Sterling 10.25 LSD
  98. Need TJ fan shroud!!!
  99. Need some Barn Wood
  100. Wanted th350 and 208 adapter
  101. Wanted jeep dana 300 t-case
  102. equipment trailer
  103. 95 sierra 4x4 frame and other parts
  104. 99 tj lift kit wanted
  105. Wanted: 215/85R16 Tires.
  106. Your 30 spline dana60 ARB for my 35 spline ARB
  107. Rear dana 60 caliper brackets
  108. Need Radiator for YJ Auto
  109. original xbox controller
  110. YJ Tank skid for poly tank
  111. Jeep TJ 2.5L engine.
  112. 6.2 or 6.5 non turbo truck or blazer
  113. Wanted 2wd crew cab project!!
  114. 06 dodge Ram engine 5.7 hemi
  115. Wtb...xj shocks 3/4" lift
  116. Custom Fab - Roll Bar
  117. 99-02 Camaro/Firebird T56 6-Speed Manual Trans
  118. lookin for a lift around 6in. for my 1996 dodge and 35's
  119. Holley double pumper carb
  120. 4.0 L block Grand Cherokee GOT ONE
  121. WTT wheels for wheels
  122. family style roll bar
  123. aluminum pontoon paddle boat
  124. TJ Y-pipe
  125. lp dana 30 carrier
  126. WTB/WTT Ranger Bushwacker Cut-Outs
  127. Turbo 350 tranny
  128. Np205 input
  129. Yamaha 350 warrior seat.
  130. Wtb: Toyota front ifs driveshaft
  131. lockers
  132. 12 bolt carrier + parts
  133. toyota exhaust manifolds
  134. wheel spacers
  135. CJ7 Fiberglass Tub, preferably used/cut and with tailgate cutout
  136. yj soft top wanted
  137. Tonka toys
  138. 1
  139. wtb/wtt 73-79 f series fan shroud
  140. Wtb complete chevy dana 60(MI)
  141. WTB: 12" manual rotary table
  142. HP dana 30 3.55 gears
  143. Powerstroke or duramax .....delete....bought one
  144. need 16.5 rims
  145. WTB Power Steering Cooler
  146. looking for a 1999 jeep cherokee sport chrysler 8.25 rear end
  147. Aw4/tcm/wiring/shifter
  148. Wheel spacer 5x5.5 1"
  149. wanted cherokee, xj trade
  150. Jeep rims
  151. rubbermaid shed
  152. 42'' tires
  153. Fuel cell
  154. Jeep 4.0 I-6 Cylinder Head
  155. TJ Tub with title
  156. water tank truck/ trailer
  157. WTB-stock YJ springs
  158. need 4.0
  159. xj winch bumper
  160. Jeep 4.0
  161. Need Radiator and Carburator
  162. WTB Jerry can lid
  163. yj half doors
  164. Recurve/long bow **FOUND**
  165. Want junk optmua red tops
  166. i need 4 wagoneer/chevy calipers
  167. tj stock pitman arm
  168. WJ Hitch
  169. TJ sound bar with connector!
  170. looking for a truck camper
  171. one 42x17 needed for spare
  172. Wanted- used Remington 870
  173. Stock tj swaybar links cheap
  174. Honda 250ex exhaust
  175. SHO electric fan
  176. Partial YJ or TJ frame
  177. cv shafts explorer/ranger 96 -
  178. dana 30 with any gears 3.73 gears are best
  179. Wanted 231J or 242J Southern lower Mi
  180. 8.8 axle
  181. cj6 lift springs
  182. wanted good p pump for a cummins
  183. Need wj parts
  184. looking for some jeep parts
  185. wtb mud tires
  186. yj front seat brackets
  187. 15x8 5x4.5 wheels
  188. Yamaha Blaster exhaust
  189. Kid needs CHEEP but road worthy car
  190. 2 " lift, for JK, 35's for 18 inch rim
  191. I need 3 motors!!!
  192. 22re needed asap!!!
  193. Snowplow mechanic on the Westside...(think cold lol)
  194. candy land, shoots & ladders, banana seat
  195. jd2 model 3 dies wanted
  196. Jeep tj frame, or A 66 to 76 Bronco Frame
  197. 31x9.5x15
  198. RC Plane (trainer)
  199. Wtt 37s for 35s
  200. Trailer
  201. looking for some 285's or 305's for 16 inch rim
  202. 37x12.5x17 tire
  203. super chharger kit for a 4.0
  204. WTB, Chevy dana60, 14 bolt
  205. 15" or 16" rims for ranger
  206. JCR or equivalent bumpers for 00 XJ
  207. 15x8or9 6 on 5.5 4or less BS
  208. 33-35 x 10.5 R16 Tires
  209. Grand Wagoneer Rear Dana 44
  210. 73-87 front lift springs 8 or 10 inch
  211. WANTED!@ 1979 F250 Shock mount
  212. spice colored soft window
  213. xj sheetmetal
  214. Yamaha Vmax
  215. Wanted: Ford 9" Detroit locker
  216. Wanted Scout II power steering boxes
  217. Utility trailer
  218. Looking for an np242 for my ZJ ***DON'T NEED***
  219. ROLL BAR / light bar
  220. a/c pump
  221. looking for a tj
  222. 1
  223. needed MT 35x12.5x15 mtx
  224. wtb xj cherokee leaf springs, s10 springs, jk shocks
  225. trail rig
  226. wtb big shell casings
  227. 93-98 grand cherokee front driveshaft
  228. 35 spline FF dana 70 rear axle shaft
  229. tj frame
  230. 16x10 8x6.5 wheels
  231. Aw4 trans
  232. PSP movies & games
  233. Need Good jeep 4.0 Crank!!!
  234. 8 on 6.5 rollers
  235. need 4.0 for 97 zj
  236. WJ Bumper
  237. wtb 35s
  238. tj soft top
  239. Low hood flat fender tub and windshield frame
  240. dana 60 kingping rebuild kit
  241. WTB scooter or moped
  242. gears for ford 8.8 and dana 30 hi or low pinion
  243. xj clutch pedal assem.
  244. Wtb hp d44 and 9" gears
  245. dana 35 open carrier for 97 tj with 4.10's
  246. 350 chevy turbo transmission
  247. WTB rear 4.10 Dana 60 8 lug for 69 F250
  248. WTB: Big bearing D44, Lake Orion, MI
  249. TJ engine wiring harness 2003
  250. 2" Coil Spacer for TJ OR 2" Lift Coil Spring
