  1. wanted jeep clip
  2. wtb CJ radio antenna assy.
  3. Set of 4 or 5 33/12.5or10.5/15s
  4. dana 30 front axle shafts
  5. Looking to trade my Wheels and tires for somthing to put on truck to trade in
  6. bronco parts
  7. CJ Tail light wiring harness and Front turn singles
  8. WTB 4 or 5 basic black steel rims for a TJ. 15x10. Running 33-12.5-15s.
  9. depth finder/fish finder
  10. WTB: XJ Outer axles
  11. wtb 33x12.5x15 m/t tires and yj offset wheels
  12. I need some stuff
  13. Trailer
  14. MSD Box
  15. Chevy pickup motor mounts
  16. yj speader bars
  17. cj windshied with glass
  18. WTB yj stock leaf springs
  19. Wanted: TJ trans dip-stick tube.
  20. Garmin ETrex Map Software
  21. 1 bogger 18/39.5/16.5
  22. need a ford 4.0 ohv motor
  23. Gen 1 Ranger Grille
  24. Childs power wheels for boy 50-200 cash
  25. Tranfer case for a GMC 2000 SERRA Z 71 5.3 LITER
  26. Mini Bike
  27. 31" to 34" Mud Tires
  28. WTB: 454 4 bolt block.
  29. 500 Caddy V-8
  30. cherokee driveshafts
  31. 17" 5x5.5 rims
  32. Need G8 Parts
  33. CJ,YJ,TJ, v-8 must
  34. 35" General Grabber AP or similar all terrain
  35. Xj or Mj clutch pedal assembly
  36. 1 - 31x10.5x15 tire **FOUND**
  37. wanted tube bent nera holland/allegan area
  38. Looking for a ax15 and pedal assembly
  39. looking for wheels
  40. 73-87 k-10 suspension stock.
  41. WANTED: 31x10.5x15 tires on or off wheels
  42. carb rebuilt
  43. trade waggy d44's for chevy half tons
  44. Trans
  45. YJ Gas Tank Needed
  46. xj hood
  47. Running wrangler
  48. wtb 31" or 32" mudders
  49. 84-86 jeep cherokee any condition
  50. YJ Family Style Roll Bar?
  51. need durango transfer case part
  52. Just a nice jeep
  53. 31-10.50-15 or 32-11.50-15
  54. 83' Jeep CJ dash panel
  55. 1988 f150 lift springs
  56. wtb gmc-chevy z71 4door or trailblazers have cash in hand
  57. TJ 4 Cylinder Fan Shroud
  58. nv4500 or 5600
  59. WTB 8 lug 15x12 wheels
  60. Bumper for the Pastor
  61. Ranger/Explorer manual lockouts
  62. SBC headers and 3-4" lift for K5
  63. Vcr
  64. np242
  65. 90 f250 parts
  66. *parts acquired*'91-'95 AW4 parts, trades listed
  67. WTB coilovers
  68. 2000-02 Jeep TJ Sahara wanted
  69. tig welding help
  70. Hydro steering stuff, 40+ tires
  71. yj tub
  72. chevy 6.0L
  73. coilovers
  74. wtb: 4.88 gears for hp dana 44.
  75. WTB: tires----no longer needed
  76. h1 wheels
  77. looking for 2000 xj 4.0l
  78. Dana 30 ring and pinion
  79. Wrangler TJ Trunk
  80. ***Made my own ****Looking for a 78-79 Ford Bronco front bumper
  81. WTB Dirt Bike or ATV
  82. WTB: 98-01 Dodge Ram
  83. pinstriping in Grand Rapids wanted
  84. WTB: Vintage Mini Bikes
  85. Canoe
  86. 911 (steering box) !!!!!!
  87. NOT NEEDED Wtb 4.2L
  88. Wanted Ground Hawg 17/40 15s
  89. WTB Cheap 4 Wheeler
  90. Looking for 33's
  91. looking for cj parts
  92. 84 258 dipstick tube/aluminum power steering pump bracket
  93. Little league stuff
  94. WTB: 5 on 4.5 to 5 on 5.5 wheel adapters (4)
  95. '97 Wrangler Radiator
  96. wanted dodge ram transmission 545rfe
  97. WTB 12x16 wheels
  98. Dana 30 with 410s
  99. WTB: tj 2.5L motor
  100. rear bumper cover for a 94 zj
  101. dana 30 short axle shaft for xj
  102. wtb: XJ fan shroud
  103. Wanted: A Job in/near oakland/macomb counties
  104. 99-2006 gm 1/2 ton front axle needed.
  105. 31 10.5 15 mt style tire
  106. tpi transported
  107. Dana 44 narrow trac
  108. Wanted - 97 / 98 ZJ Rear Lift Gate
  109. looking for 4.10 ring and pinion for dana 35
  110. Known good XJ 4.0
  111. 98 xj passenger mirror.
  112. 35 12.50 x 15 mud tire for spare
  113. Rebuilt 5R55E in Explorer transmission
  114. 97+ xj front clip and radiator
  115. A set of 5x4.5 wheel spacers
  116. looking for those 275 gallon plastic totes
  117. wtb or wtt for jeep zj parts
  118. s10 wheels and tires
  119. 99 xj a/c compressor
  120. dana 60 cap
  121. Need a Radiator for a 1976 cj7
  122. Good Used Tires?
  123. yj windsheild frame with glass and wiper stuff
  124. WANTED: RV Water Heater
  125. WTB 1980-1987 Toyota 4x4
  126. Need a motor swapped!
  127. F150 5 lug rim
  128. 2" 1/4 wall
  129. 97+ ohc wire harness
  130. I Need a 1994 Ford Ranger A4LD - 2 wheel drive automatic tranny
  131. s10 bed and brushguard
  132. Gm 60 lock out ?? dually Hub Mine stolen
  133. Looking for a TJ in Michigan
  134. tri fold tonneau cover 6.5ft bed
  135. RIMS: 15x8" 5x5.5" for CJ
  136. dodge np208
  137. 6 lug rims
  138. rockwell rollers
  139. AX5 5th gear snap ring
  140. Ranger rim
  141. poles
  142. Ranger or s10
  143. 18 in 5x4.5 rims
  144. 4" lift coils
  145. '88-'98 Chevy/GMC Bed sides
  146. Wanted: Dodge and Ford steering boxes
  147. wtb orbital
  148. Wtb: Xj front bumper
  149. dana 50
  150. black tj soft top
  151. 203 gear reduction box and adapter for th350
  152. amc rocker arm bridges
  153. RIMS 15x10 or 15x8 with 3-4" offset 5x4.5
  154. looking for a motor for a yanaha rhino 660
  155. 01-04 duramax lb7
  156. Ford 302 HO Complete
  157. F350 fender flares
  158. 5x4.5 wheel spacers
  159. Wrangler TJ WHITE
  160. wtb 39 mickeys and 15x14 8lugs!!
  161. Rear quarter side glass.XJ
  162. low tread 40s
  163. part time kit 203 tcase
  164. HD Softail help - Rear Amber signal lens
  165. MAP sensor for a 94-98 7.3L Diesel
  166. Air Compressor
  167. dana 300
  168. portable a.c unit
  169. sb dodge intake
  170. Wtb 98-01 xj fenders
  171. Manik Brush Guard for 97 TJ
  172. Sand Paddles
  173. tires and fenders
  174. Disney Cars DVD
  175. Rent a Jet-Ski trailer
  176. TJ bestop full soft doors
  177. lap top repair
  178. Any jetski guys? I will buy your jetski
  179. Wanted: 06+ Dodge 1500 AND 04+ Dodge Nitro
  180. D60 1350 pinion yoke
  181. 47re
  182. dana 20 t case
  183. Wtb boss rt3 plow/s
  184. WTB 1990-1996 F150 2WD 4.9l
  185. wtb: car dolly
  186. Looking for a Jeep TJ factory a/c for a 98.
  187. Need Dana 30 Front Hub/Lockout (5 bolt - 27 spline)
  188. 38.5-15 Ground Hawg
  189. WTB 33/12.50/15 At's or MT's
  190. Vehicle
  191. 1999 WJ grand cherokee w/5.5" lift for trade *delete*
  192. Stock JK knuckles
  193. stock xj shocks
  194. 225/75/15 trailer tire.
  195. Jeep/buggy with 1 ton axles or ?
  196. chevy or dodge 60 hubs
  197. 88-98 rear leaf hangers
  198. 315/70-17 BFG AT, need 1, CLOSED, no longer need 1
  199. YJ transfer case skid
  200. Char-linn valve
  201. Windshield light brackets for 97 Tj
  202. GM Short&Long 3/4 ton 28 Spline axle shafts
  203. Decent 16" 8-lug wheels for a 2000 Chevy
  204. 95_99 xj with blown motor
  205. Driver side mirror
  206. 98 xj sye drive shaft
  207. 4.27 gears for Dana 30 OR 3.54 gears for Dana 44
  208. new DD for the wife
  209. WTB late 70s to mid 80s Short bed/stepside box
  210. Looking for T176/dana 300 combo for Cj
  211. YJ Parts Wanted
  212. Feb-April 2012 issue(s) of Jp Magazine
  213. Wtb: Toyota 3.0l for my 89 sas pickup
  214. Sprinter Technician
  215. H-1's
  216. Tow hooks and/or Trailer hitch
  217. Carpet for TJ
  218. jeepster comando rear axle
  219. CJ7 Bumper Tire Carrier Wanted
  220. Xj dana 30 with 4.10
  221. YJ 32rh / chrysler 999 3spd auto
  222. Need a Verizon phone
  223. 17" wheels
  224. XJ Rear Window
  225. H2 wheels
  226. Mud terrains for 17 inch wheels
  227. axle shafts
  228. duce drive shaft
  229. YJ 4 cyl. motor mount
  230. Wanted motorcycle/enduro $2500
  231. Wtb looking for 50 hp outboard
  232. 50-75 hp outboard
  233. Rear axle/or parts for a CJ Rear.
  234. JK track bars
  235. Cj7
  236. Willys wagon, or truck.
  237. 3.8 series 1 GM v6 motor .
  238. WTB: 220V Lincoln/Miller/Hobart/Esab MIG
  239. sbc
  240. 32" or 33" tires
  241. XR 650L Rims
  242. Wanted: VW 1600 and Trans-axle
  243. Supermoto tires for pit bike, and other aftermarket stuff
  244. need good ax-15 asap
  245. front tj shocks for 2" lift used/new
  246. 16.5" rims in 5 lug variety
  247. Looking for some 38.5x15x16.5 tires!
  248. Flowmaster and tool box
  249. Looking for 87-95 Wrangler
  250. wtb boggers with low tread
