  1. yj lift 2.5-3"
  2. 4.56 gears for 8.8
  3. transfer case
  4. 231/231 DOubler
  5. One ford lock out
  6. 33x14.00x15 Boggers NEED 2 only
  7. insulation free or cheap
  8. XJ Radio Antenna
  9. 46RE Tail Housing
  10. 247j t-case out of a grand
  11. 245/75/16 or 31/10.5/16 tires
  12. adapter
  13. pinion shim
  14. tj pcm
  15. tj pcm
  16. side windows for a hardtop 1997 to 2003
  17. 98 ext cab dodge 2500 parts
  18. 1992 Toyota Frame
  19. wtb wrangler fenders,hood,tailgate,etc
  20. wtb parts for my 96 cherokee
  21. 2004 crf250 trade for jeep
  22. TJ Full Doors
  23. GM 6 Lugs Rims 15" to 20"
  24. WTB 3/4-1 ton diesel truck
  25. Ride a Soldier Home
  26. 16.5 x 12-ish beadlocks
  27. wanted xj 4.5 coils
  28. 94 cherokee hatch red
  29. Mile Marker Winch parts
  30. looking for good 16.5 tires
  31. 8.25 spanner tool to borrow
  32. 35x12.50x15 mud terrains wanted
  33. 89 XJ Rear drum brake parts
  34. 350 chevy engine
  35. trade for a 4x4 truck
  36. looking for tires
  37. WTB-good used dana 44 and 9" locker
  38. 12 gauge shotgun
  39. DeleteNeed a set of 15-10 or 12 8 lug rims. Delete
  40. not needed anymore..
  41. Tires 36-44" for a 15" rim
  42. YJ Door Handle~ INSIDE
  43. *delete* 15" 8 lug wheels * delete*
  44. Looking for flanged CJ5 D44 or 19 spline D44
  45. T350 transmissions for cores
  46. 3" lift front coil springs for a 97 Cherokee.
  47. Chevy engine
  48. 1996 4l60e transmission
  49. toyota carrier and spiders or spool or complete 3rd with 4.10's
  50. 3.73 gears, hp dana 30
  51. Wtb locker for 98 Xj Dana 30 front
  52. pewter fender for chevy
  53. th400 np205
  54. center console for bench seat
  55. Rims or aftermarket parts for 2003 expedition
  56. toyota front leafs
  57. F150 parts
  58. wheels for superduty
  59. Torqshift 5r110 trans
  60. 2nd Gen Dodge Lights
  61. I need four rollers. 8 lug. cheaper the better
  62. 1996 and earlier Ford F250 (F150) Tailgate needed
  63. 1
  64. "Arcade" games...
  65. Waggy axle
  66. R4 for 2.8 /// 2.8 automatic trans. GM/ Jeep
  67. 265 x 75-16 Load Range E tires - aggressive tread in 75% or better condition
  68. jk rubicon rear locker
  69. 1 33x10.50x15 Tsl Interco
  70. 17in 8 lug wheels
  71. Wheel horse hub
  72. vinyl cab work mat
  73. 8.8 carrier
  74. looking for a 4 seater dune buggy
  75. ground hawgs 35-38's for 15 or 16.5 rim
  76. air cleaner
  77. Kids dirtbike or quad
  78. 2x4" or 4x4" square tubing
  79. Tera Low Kit for Dana 20 T-case
  80. looking for Rubicon Fender Flairs
  81. 3.42 gear set for a GM 14 bolt
  82. Ford king pin Dana 60
  83. D44 Lockouts or Slugs
  84. YJ HVAC unit GOT ONE, THANKS
  85. 97+ XJ Passeneger side leather seat
  86. Right side doors 03 and up dodge ram Quadcab
  87. 8 lug rims/beadlocks and 35-37 tires
  88. Looking for washer bottle 93 YJ
  89. 2004 wrangler axles
  90. Need Exhaust Shop In Grand Rapids Area
  91. 1978 and earlier 429/460 flywheel for manual trans
  92. I need 35x12.5x16.5 tires
  93. chevy ash tray
  94. YJ Soft Top Hardware
  95. 20 in tires
  96. dana 44 4.88
  97. i need a fiberglass jeep tub!
  98. Want Dana 44 4.88 Standard Rotation Ring & Pinion
  99. 42re
  100. cheap/free/loaner 8 lug rollers
  101. wtb cj7/wrangler tub
  102. 1 38.5 x 1450 x 15 tsl sx
  103. Lifted 4x4 wanted
  104. 351 w (injected)
  105. old ford radius arms
  106. Dash heater vent grill for TJ
  107. Ford hubs needed
  108. full width hp d44 drivers drop housing
  109. Jeep zj
  110. WTB: 78/79 Ford HP60 Chromo Inners
  111. Diamond plate corner guards for TJ
  112. 96 Explorer
  113. Wanted, old busted Keurig, need water tank, lid, sorry doesn't belong in wanted parts
  114. 9" 31 spline spool
  115. (2) 15x8 soft 8s 5 on 4.5
  116. 33" or 34" tires on Chevy 6 lug rims
  117. YJ half door inner door skins black
  118. spare 33's?
  119. h1 rock rings
  120. Gas Tank & Skidplate for 1975 CJ5
  121. Waggy springs.....
  122. Need 15x10 rim 8on6.5
  123. 97 ranger
  124. Jeep Wrangler (YJ) driver-side fender
  125. One single 1 Ecco wheel for 99 Cherokee
  126. 4.0 bellhousing
  127. Dana 44 locker & 5 on 5.5 15x10
  128. 241 shifter
  129. Ford 9.75 rear axle
  130. Dana 30 456 gears
  131. In Need of a 304 Flywheel
  132. argon cylinder
  133. XJ lifted rear leafs wanted, full/ bastard or aal
  134. 99 WJ 4.7 starter
  135. used truck or suv
  136. 03 Tracker Parts
  137. wtb 2x4 box tube
  138. WTB XJ Adj. Trac Bar / DisConnects 4-6" Lift
  139. stock tj gas tank skid
  140. *DELETE* 17x9 8x6.5 wheels *DELETE*
  141. Mossberg 12ga chokes
  142. Carpet 1998 Wrangler TJ
  143. Chevy Dana 60 parts
  144. 31,10.50x15 bfg wanted
  145. WTB Grand Cherokee
  146. jeep 4.0 starter
  147. wtb 2004+ 440 rev
  148. 1 Cooper Discover STT 33x12.50xr15
  149. wanted 1 18.5x44x16.5 ground hawg
  150. wtt 99cr 250
  151. 23 spline out put trans
  152. WTB: XJ front ds and console
  153. 14 bolt hubs.
  154. tire groover
  155. 2.5 motor for tj
  156. anyone have a 8000lb winch they wanna sell
  157. WTB 00 Superduty Tailgate
  158. Tj bikini top
  159. to cheap to buy new need 32-33inch tires for 15 inch rim have 600 to spend
  160. Crew cab Chevy 4x4 short box.
  161. TJ softtop - spice or white in color
  162. vacuum motor for a np229 transfer case
  163. DELETE - no longer wanted
  164. Focus rim and tire
  165. WTB: OME 2" lift for an XJ
  166. coral reef aquarium
  167. Wj climate control blower resister
  168. 4.0 for 2002 Wrangler
  169. h1 beadlocks with or without tires
  170. wanted lift for 95 chevy 1500
  171. tj front axle shafts
  172. Feeler: 4.0 liter long block with low miles
  173. Contractor cap for 1994-01 Ram wanted
  174. Need a Cummins 12V 98 PCM
  175. head for 02 tj 4.0
  176. YJ Family RollBar
  177. YJ steering box
  178. portable dvd player
  179. Looking for a set of 33s
  180. WTB 97-01 Jeep TJ 4.0l 5spd
  181. Wanted a cheap 4.0
  182. 125CC Karts
  183. late 90's mustang project
  184. Trade TJ full doors Yellow for Blue
  185. looking for tube/safari doors for my tj
  186. Cherokee trade for tj yj
  187. I know this is a longshot. Anybody have a set of 6.9 dual carbide skis for sale?
  188. Feeler: Looking for a diesel suburban
  189. WTb XJ coil springs
  190. Ford Parts
  191. wtt yj gray soft top
  192. looking for free used motor oil
  193. WTB 2 decent 235/75/15
  194. manual locking hubs for 99 ranger
  195. WTB: TJ RT Full Door, RT FR Fender, 1 225x70Rx15 tire
  196. Wanted: Someone that knows Model A's that may want a project to tinker with.
  197. 16" black rims
  198. 88 to 98 gm front clip
  199. stock jeep rims or any 5x4.5
  200. Anyone seen this 1967 Camaro ????????
  201. wanted 1967-1973 camaro
  202. Need 36'' or bigger for 16'' rims. Or rims and tires for 97 dodge 4x4!!
  203. HP D30 locker
  204. 2wd th350
  205. 1977 CJ5 Frame
  206. Dodge parts needed
  207. Have $2500 to blow on a rig
  208. xj electric fan
  209. zj hatch/rear bumper and cover.
  210. 4.3vortec 4l60e and wiring
  211. 16.5" rim size tires 37+"
  212. xj locker
  213. WTB: Mig welder
  214. Wanted. TTB Drop Brackets D44
  215. non textured XJ bumper end caps front and rear
  216. tj 2.5 header downpipe needed asap
  217. TJ Rubicon Front Locker (or Spiders)
  218. Need Ax-5
  219. ZJ front driveshaft bolts for cv driveshaft
  220. efi 460 headss
  221. Xj bushwackers
  222. 17x9 wheels
  223. WTT Scaner for Jeep
  224. cj7 top
  225. wtb trailer tires
  226. wtt clean 2004 neon for clean mini truck
  227. r/c car for front axle
  228. Jeep Comando project
  229. Jeep Parts
  230. NEEDED: jeep tj grill plus other stuff
  231. YJ or XJ
  232. needed 33x12.5x15's
  233. Jeep YJ D30 rotors
  234. Jeep WJ D30 knuckles
  235. Carb intake manifold for chevy 4.3
  236. 285 tires
  237. 1994 and lower cherokee seats
  238. stock TJ t-case shifter
  239. Dodge Dana 60 axle shaft
  240. TJ Dana 35 Open carrier for 4.10 gears -OR- Trac Loc / Locker
  241. xj parts
  242. 15in rim with lots of back space 5-4.5
  243. ford dana 44 8 lug parts
  244. Need spare tire 99 ranger p205/70r15
  245. Need 1 305/65/17 (33") for spare
  246. 98 xj rear doors
  247. WTB Jeep Cherokee
  248. Black TJ Full Doors
  249. 4.0 flywheel
  250. WANTED: CJ7 Light/Dimmer switch
