Wanted [Archive] - Page 11 - Great Lakes 4x4. The largest offroad forum in the Midwest
  1. wanted: a friend in Lansing with a garage
  2. dana 30
  3. wanted a XJ or MJ
  4. zj dana 30 with 355s
  5. chevy 10 bolt front
  6. hummer bead locks
  7. Wanted: Nextel Flip phone
  8. 5 points and buckets
  9. D35 Locker or LSD
  10. 35 inch spare
  11. wtb: 98 ZJ front drive shaft
  12. wtb: rims for dodge
  13. tj har doors
  14. 5 speed 3550
  15. needed: 4.88 or 5.29 gears for yota and 1 36" Irok
  16. hitch for '96 tracker
  17. Trooper Trans/T-case
  18. front 4x4 vac acuator
  19. 97 Tj Radiator
  20. lower control arm for a zj
  21. trailer
  22. (1) 35x12.50x15 Mtr
  23. 33" tires
  24. 42s or 44s
  25. 235/75-15 BFG at or geolander a/t
  26. toyota front axle
  27. Beater Jeep With An Amc V8, Or An Amc V-8
  28. looking for ford d44 4.09 centersection, or just carrier and gear with shims.
  29. Looking for a Cj
  30. 3 or 4 core Radiator
  31. long shot balancer for a 3.8
  32. Chevy NP 203 Tcase & Adapter
  33. center caps
  34. 2000 Cherokee XJ parts 97-01
  35. NV3550 shifter
  36. WTB: Jeep J-Truck
  37. need stock yj leafs that are still good
  38. 17 in tires
  39. 33s
  40. center caps
  41. cheap hitch cover
  42. YJ softtop
  43. Tj Fender Flares
  44. 35x12.5x15 tires
  45. snow plow 7.5'
  46. trans for 99 TJ.
  47. Small brushog/pull behind mower
  48. need np242 for 93 ZJ
  49. Wanted Subaru Brat
  50. long box truck cap
  51. wtb fsj with v8
  52. yj springs
  53. Cap for shortbox Dodge
  54. stering wheel for 04 tj
  55. wtb: 22 rifle for my son
  56. round tj hood bumpers
  57. CJ7 Frame
  58. WTB BFG Radial A/T's 31 X 10.50 - 15
  59. 95+ Tacoma or 4Runner rear axle
  60. looking for A 4x4
  61. 33x12.50x15 trXus M/T - GOT ONE
  62. Wanted AX-15 and T-fer case for 89 MJ
  63. FSJ parts
  64. 32" MTR's
  65. Tj stuff
  66. yj roll bar 1992 to 1995
  67. carb for 4.2
  68. YJ front driveshaft
  69. CJ3B 4.27 gears
  70. SBC intake manifold
  71. looking for a 4.0L for a 96 ZJ
  72. Wtb: 97+ Tj
  73. wanted to trade
  74. TJ fog light bracket
  75. 33x12.50-15
  76. Rear Half Of Driveshaft For Yj Wrangler
  77. Stock XJ tires and maybe wheels
  78. Wtb 16" Tires 8-10 Ply-rating For 3/4 Ton Truck
  79. tensioner bolt
  80. 35 inch spare
  81. door hinges for tj
  82. WTB: Tires and Rims for jeep
  83. 77 chevy windshield
  84. adjustable lower control arms for a TJ,ZJ, XJ
  85. Stock Yj Springs
  86. wood stove
  87. jeep or small truck
  88. tj tlares
  89. dana 44 narrow track shaft
  90. FSJ AMC 20 rear axle
  91. sye and cv for 97 xj
  92. throttle cable bracket for 360
  93. xmas Wreath
  94. Lookin for rockwells
  95. 1st Gen 4Runner Parts
  96. lookin to rent a 28 foot Trailer..
  97. trade R16 tires for R15 tires
  98. pickup tool box
  99. 12"-16" wide aluminum wheels with 5 x 51/2 bolt pattern and tires
  100. pre 92 xcab ranger
  101. drive shaft
  102. BSA engines?
  103. Topper for a 1999 Dodge Ram w/6.5' bed
  104. need 8.8 asap
  105. Winter storage for vehicle
  106. YJ 4 liter frame side weld-on motor mounts.
  107. 97 - newer XJ doors
  108. 1990 chevy steering column
  109. Electric Fuel Pump
  110. *No Longer Needed* 245/75 - 265/75 R16's
  111. XJ dana 30 front
  112. wanted trans for 98 caravan
  113. 30" wheels and tires
  114. WANTED: Double Axle Car Trailer
  115. Chevy springs
  116. XJ 3 inch Budget Boost
  117. need good e40d cheap.
  118. 37" spare
  119. 16x10" 8lug 6.5" bolt circle rims
  120. Rockwell front short side axle shaft.
  121. up-graded steering box for YJ
  122. Reliable car/truck $1500-$2000 range
  123. WTB built cj/yj rolling chassi
  124. XJ driver's seat
  125. tires, for stock XJ
  126. Jet boat
  127. Tj
  128. I Need A Flange/yolke For A F150
  129. YJ windshield frame
  130. someone to do an alignment
  131. need 2 215-60-15 tires
  132. TJ headlight bucket/frame/saddle.... its plastic
  133. TJ Soft Top Windshield Header Bar
  134. wanted wrangler......
  135. TJ dana 35 w/4.10s
  136. TJ windsheild frame
  137. Need ford NP205
  138. welder
  139. 8-10hp verticle shaft motor
  140. chevy lift and tires
  141. 12 volt xmas lights
  142. factory fog light switch for a jeep
  143. TJ foglights and switch
  144. CJ grill
  145. CJ stock pitman arm/dash board?
  146. 34x9.5 - 16 TSL's OR 15"
  147. Air Compressor/misc
  148. looking for a cheap carb for a sbc
  149. A set of 37" or 38" tires for 16" wheels
  150. 265/75r16 or similar D or E tires 4
  151. trans adapter 465 tansmission
  152. WANTED matching set of gears for fatory 91 jimmy fullsize axels
  153. Wanted junk cj frame
  154. Xj Aw-4
  155. 17" 8 lug steel wheels
  156. cheap/free tires on rims for Dakota (being stored for winter)
  157. 01 XJ 4-dr rear quarter glass(please remove)
  158. 31x10.50 15 mud tires
  159. needed 456 gear for 8.5 10 bolt front end
  160. 17" envoy/trailblazer/? rims&tires
  161. Cj 5 seat
  162. fullsize chevy blazer rear bench seat
  163. **all set**tow dolly to borrow or someone to tow for me
  164. re4.5" coils or 4 1.75" coil spacers.
  165. leaf springs wanted
  166. zj tie rod
  167. TH400 and NP208 parts
  168. small trail rig
  169. single phase 5 hp motor
  170. car rims 16" 5 on 4.5 BP
  171. 22re fuel pump/tank fuel cell
  172. looking for fender flares
  173. WTTrade 35's for 37's or 38's
  174. 31 in mickey tom, claws for spare
  175. d30 xj nondisco spider gears
  176. 77 CJ7 backing Plate
  177. 2" BB spacer
  178. 225/75 R15 Tires for XJ!!
  179. Yj seat frame
  180. 33x12.5x15 BFG Mud Terrain
  181. Looking for set of Ecco or Icon Wheels
  182. cheap chevy fullsize axles (10/12 bolt, dana 44s, etc)
  183. cj power steering shaft
  184. 16.5" rim 5x5.5 bolt patern
  185. 2x4 box steel
  186. tj half doors/ safari doors
  187. YJ parts
  188. Tires
  189. WTB: nice set of wheels for an XJ
  190. female american bulldog puppy
  191. 4bbl intake for ford 400
  192. TJ Front Bumper.....
  193. tj full doors
  194. Power steering bracket and 5" fender flares
  195. Wanted - 4.88's for D44/9"
  196. 4.0L Power steering pump
  197. TH400 to dana 300
  198. dana 44
  199. YJ 4.0 Block Mounts
  200. JTEC connector
  201. Someone headed by saginaw to warren area to haul 12' roll of carpet and pad
  202. 4" yj springs
  203. Rent/Borrow a Carhauler
  204. WTT 96 CR 250r FOR xj parts etc.
  205. need 12 bolt rearend with 4.10
  206. 5.5 inch to 4.5 inch wheel spacers/adapters
  207. Cheap Motor Oil
  208. 1 15x8 Black Steel Rim 5 on 4.5
  209. yj soft top
  210. winch
  211. ***Want BEER***Need Help Saturday Morning 12/09/06
  212. Rock rails
  213. Washer pump
  214. electric motor
  215. Dana 35, 3:55 axle
  216. Dana 44 carrier
  217. wtb. d35 front detroit locker / 9" 28spline detroit locker
  218. Old 3 wheeler or quad for a winter project but cheap!
  219. 4 things that I need before I install my first lift kit.....
  220. need power steering pump toyota
  221. Sound Bar YJ
  222. 23 spline NP242 for an XJ
  223. Wanted 4.0 Throttle body
  224. 700R4 to Dana 300
  225. stock front coil isolators
  226. Spare Rim 8 lugger
  227. Tire Holder
  228. Winch
  229. 95-96 Expolder center axle disconect.
  230. air shocks
  231. dana 30 ox locker
  232. 4:88's for dana 30 and 44
  233. 40lb - 120lb Dumbells
  234. 1/2 door uppers to fit hard top
  235. Stock chevy 3/4 or 1 ton rear leafs and 6-8 inch lift front leafs
  236. Wanted Open Car trailer
  237. 97 and up XJ front/rear bumpers
  238. Lugnuts
  239. WTB or Borrow 4x8 or 5x8 utility trailer
  240. Rims- 15x8-5x.5.5
  241. Stock YJ leaf springs
  242. Looking for 16.5" rims 8 lug
  243. 2.5 Ton Rockwells
  244. Use of a lathe in SE mich for 2 hours
  245. cj5 rear shackles and greasable bolts/bushings
  246. A set of 16x10 8 lug rims
  247. 33x10.5 BFGs
  248. old soft top
  249. 40 series flowmaster
  250. ~16" of 1" ID tube
