  1. WTB 10 or 12" coilovers
  2. looking for a car
  3. wrangler wheels
  4. gantry crane or pieces to make
  5. 15x8 or 10 5x4.5 wheels wanted-prefer aluminum
  6. Yj rear seat
  7. wrangler 94 or newer
  8. Quality Truck Shock Absorbers - Who Stocks them in Detroit Area?
  9. 93 YJ bestop driverside soft window- good cond. black
  10. toyota transfer case stick asap
  11. 03-06 TJ rear window (softtop)
  12. WTB 4.5"+ xj lift
  13. Rocks/boulders, football-beach ball size.
  14. AX-15 with TC
  15. Mid 70s Camaro
  16. 17x10 8 lugs
  17. tj seats
  18. WTB-looking for CJ7 parts...
  19. WANTED: D30/Gears/locker/LCA/UCA
  20. 4 stroke 450 YZ RM KX
  21. CJ dash parts, steering column
  22. 00 Cherokee Trade for Open Top Jeep
  23. Scout D44
  24. wanted asap rear driveshaft.
  25. Th400 long output shaft
  26. Need asap dana 30 3.73 ring and pinion DANA 30 NOT 35 MY BAD
  27. looking for some 33's...
  28. Dana 44 ring and pinion.
  29. Need a D30 for my 93 XJ
  30. 1 12" wide, Wide 5 aluminum rim
  31. NP246 32 spline SOON.
  32. Dozer ''bull dozer'' nice shape.........
  33. xj sunvisor
  34. 4.0 L Motor (tj)
  35. anothr 650sx motor
  36. camper
  37. 1989-1993 S10 or Blazer
  38. 88-? Chevy 4x4 Radiator for automatic trans
  39. carb to tbi adapter
  40. 1997 RAM 2500 passenger door-
  41. Dana 20 NT 1 Piece axle shafts
  42. XJ rear springs, wheels, tires
  43. 93 to 96 Grand Cherokee Backing Plates
  44. chevy Hydraulic cluth pedal assembly
  45. NP231 transfer case
  46. 2.5 TJ manual computer
  47. Dana 30 TJ housing - driveshaft - 231 t case - wheels - tires
  48. WANTED one 35 x14.50x16.5 thornbird
  49. I need a dana 44 frontend for 97 tj
  50. wtb 5.13s for dana 60
  51. garage Door
  52. wanted: YJ Hard Top rear windows non-tinted, seals, + rear hatch hinges
  53. 80-96 ford bronco tub or extended cab
  54. Want 35 inch tires only. 15 inch wheels
  55. Looking for an Ok TJ Tub
  56. Dana 44 for 77-79 f250
  57. Firefighter looking for Red lights, siren, or speaker
  58. looking for a set of 33inch mts
  59. 94-95 s10, sonoma, blazer, jimmy tbi engine harness
  60. Outboard, Tiller
  61. trade stock cj5 axles for dana 44
  62. J-truck front clip
  63. LS1 or LT1 V8 with/without trans
  64. Wanted asap: 4x4 truck or jeep please
  65. Small Boat Motor
  66. wanted free set of 31" 10.50 15 tires
  67. someone in fenton/ hartland with 5x4.5
  68. cj7 rims and tires for trade...
  69. 1000cc buggy 7500 or trade for ur ..........
  70. 9mm Semi auto
  71. I'm in need of a gokart clutch.
  72. Dana 60 E locker
  73. cheap plow truck
  74. Small fishing boat
  75. Gm nv4500
  76. np 231
  77. in need of 3" or 4.5" xj coils
  78. Rear yoke needed Chevy 1/2 ton
  79. wanted: radiator support
  80. 3:73 and up carrier for Dana 30
  81. TJ Hardtop parts
  82. Chrysler TF999 Inspection cover
  83. xj electric fan
  84. SBC 305 for 92 camaro
  85. wanted:yj dana 30 passenger axle shafts
  86. wtt 4" wrangler springs for 2"ers
  87. 98 or newer s10/sonoma body parts
  88. Drivers side 91-96 Headlight bezel.
  89. wtb rear rubi driveshaft & jack
  90. Explorer Hitch
  91. Crotchrocket
  92. WTB: cheap 35x12.50x15 tires
  93. 33 MT tire
  94. WTB: Jeep Rubicon
  95. Looking for a Raptor 660 0r 700...
  96. WTB Clean YJ fenders
  97. 1989-1995 Toyota Engine
  98. Attn; New Tire Sales Guys
  99. dodge NP205
  100. 88 ford ranger
  101. Custom Decal
  102. Gear install for cash or your favorite beverage
  103. looking for a cj tub w/tag and title
  104. XJ 6" Coils
  105. Wanted Transfer Case For AX5
  106. Jd2 dies wanted
  107. WTB or RENT: *ASAP* RE super flex joint tool.
  108. clean fill
  109. WTB toyota 15x6.5-8 rims
  110. 03 Rubicon trailer hitch
  111. Gas Tank from a 89-95 toyota pickup
  112. WTB Wire welder.
  113. Wanted: D300 Transfer Case
  114. dana 35 yoke
  115. Need help asap stuck in dorr
  116. Wanted: Dana 44 Complete Front Axle
  117. Jeep Cherokee Xj 89-01
  118. Kids size atv
  119. Looking for a solid jeep frame
  120. Green 99 XJ Hatch
  121. Ford d35 ttb front axle
  122. Need Stock front driver side outer axle shaft
  123. Hard top hinges (TJ)
  124. MJ bench or 96-02 Dakota 40/20/40 bench
  125. 35s balanced near fenton/hartland
  126. Trade 97 Civic for Jeep
  127. I need someone to Weld some new CA brackets
  128. generator head or parts
  129. Quadrajet carb, mid 70's
  130. (1) 36x12.50x15 TSL Radial
  131. 4:10 d30 cherokee
  132. 16 inch tires!!
  133. 4.10s for a cj
  134. CJ7 T15 Transmission Mount Bracket
  135. rubi wheels an tires 5x4.5
  136. ? For ranger/explorer guys/gals with 5.13s
  137. i need someone to work on my XJ or advice on a shop to take it to..
  138. WTB 8.8 open diff with 3/4 pin
  139. ford front bench seat
  140. TJ Spare tire carrier
  141. wtb: winch
  142. Drop hitch receiver buy or borrow around Flint
  143. cj7 v8 radiator
  144. IRO 3.5 lift for axles
  145. bronco tailgate glass
  146. Door lock actuators 99 Grand Cherokee
  147. WTB: Tubing Bender
  148. Forever Black ????
  149. 16.5" wheel, 8x170
  150. Ford pick-up center counsel/ jump seat gray. 92-96
  151. Bending/ Welding
  152. xj front axle shafts
  153. Steel wheel for spare !
  154. Looking for a soft top for an 80-96 fullsize bronco.
  155. i want to trade my 35s for
  156. Front Rockwell axle
  157. WTB: front driveshaft for 99 Grand Cherokee laredo or a good place to buy/rebuild one
  158. WTB-- Electric Fan Cherokee 97
  159. cj7 radiator needed
  160. Wtb/trade Tires and wheels for full size 4wd Chevy
  161. Need a 9" or Dana 60 hybrid cut down and 5.5 lug
  162. Carter bbd non feedback
  163. WANTED 97+ header panel
  164. wtb jeep cherokee lifted $500-$1000
  165. d30 axle shafts
  166. mallory/espark 6100m distributor module
  167. need 35 or 36" tires - road worthy 50%+
  168. 258.... 4.2 motor
  169. 231 sye
  170. Yj 4.0 motor mounts, frame side
  171. 35x12.50 for 17" rims
  172. any1 sellin jeep tj longarm kits?
  173. 35" km2 and walker evans bead lock 5x5.5 for spare
  174. WTB: 33x12.5x15 Tires(OHIO)
  175. Looking for a solid XJ body
  176. Looking for a set of four 235/75/15 with at least 50% tread
  177. looking for a cheap hard top for an 80-96 bronco....no longer looking
  178. Ajustable rear lower control arms for TJ.
  179. WTB TJ Tailgate Hinges 97-02
  180. th400 tailshaft and driveshafts wanted
  181. front 97 tj driveshaft
  182. Wanted:K20,K30,XJ etc asap
  183. rubicon rear flare
  184. 7.3L IDI oil cooler
  185. WTB 2nd GEN S10 PARTS
  186. 4x4
  187. 2-4 205 tires
  188. M5OD and 1350 wanted
  189. 42/15/15 tsl 1 or 4
  190. WTT lifted 93 jeep grand cherokee
  191. 46re transmission pan
  192. sport quad wanted
  193. wanted 16.5 6lug rims
  194. 4.3 TBI accessory brackets
  195. 98 Dodge 215 Turbo
  196. Injector driver for 95 powerstroke
  197. YJ filler neck / bezel / hoses
  198. Wrangler YJ Transfer Case Shifter
  199. Grand Cherokee Budget Boost
  200. 97-06 TJ Hardtop
  201. Steel 2x5 rectangle, 2x2 square, thing plate
  202. valve cover
  203. Tires 31-33
  204. Wideband O2 gauge/monitor and sensor
  205. Looking for some 31'' tires
  206. WTB full hydraulic steering
  207. WTT Gun for 33/12.5/15 M/Ts
  208. wanted: dana 35 shafts
  209. Dana 30 axle shafts
  210. K5 Chevy Blazer
  211. Ford truck gril and headlight trim
  212. tj power steering pump
  213. exhaust
  214. CB radio wanted
  215. TJ Fenders & Rubicon flares (all four)
  216. dana 60 front axle or 10 bolt
  217. 33 x12.5 tires
  218. Jeep Wanted!!! Cash in hand
  219. H2 wheels, Silver, 1 or 2
  220. wtb 231j t-case
  221. I need a trans rebuilt
  222. jimmy transmission
  223. Dodge parts ? please help, needs tcase asap
  224. need lift shackles
  225. Small trailer (for BBQ)
  226. cheap utility trailer.....
  227. hydraulic lines
  228. WTB tires 33" or 35"
  229. chevy axleshaft
  230. dana 60 drag link
  231. headers for a 2.9
  232. Wrangler front leafs
  233. CLUTCH Tickets! (7/23 Machine Shop)
  234. wanted ax5 and throttle body for 89 wrangler w2.5
  235. looking for a 4x4 in $1000-1500 range
  236. Comanche Seat belts
  237. wtb 31 for 15 inch rim
  238. 99 jeep lifted
  239. 4.5" xj coils
  240. Dodge pitman arm
  241. Nice Daily Driver 2500-4k
  242. Meyers Snow Plow Undercarriage for Jeep CJ
  243. locker or limited slip
  244. looking 4 dog
  245. TJ Rubber Shifter Boot 5 Speed
  246. F250 D44 Axle Shafts
  247. 2000 4.0 wrangler radiator
  248. Dana 60 front
  249. CJ Roll Bar
  250. 8 lug wheels and tires , prefer GM style
