  1. WTB Powertrax for Chrysler 8.25 - 29 Spline
  2. Need Grand Cherokee Transmission
  3. WTB TJ Hood
  4. Ford 205 shifter
  5. dana 60 crossover steering parts and 2wd steering box
  6. 33 to 35 inch tires
  7. full size bronco front shocks and rear suburban shocks
  8. Wanted: 2.5l jeep wrangler
  9. someone with bender near tri cities
  10. stock ford rear shocks
  11. 16.5" wheels
  12. 4.10 front axle for an XJ
  13. wtb: 4x8-6x10 utility trailer with rear ramp
  14. 96 cherokee lift
  15. Jerry can/cans
  16. TJ Front Spring Perches
  17. Radiator 1994 - 2000 454 7.4L Chevy-ish
  18. Dana 30 locker and Dana 44a locker wanted
  19. WYB YJ Frame
  20. custom made driveshaft
  21. Wanted 295/45/20 tire
  22. Thornbird tires 33x12.5x15
  23. Jeep wrangler
  24. wtb 6" lift for 73-87 chevy
  25. jeep4.0 exhaust manifold...cracked or good just need one... pay cash
  26. CJ7 Gas Tank Skid / Battery Tray
  27. 95 chevy parts needed
  28. jeep tj stuff needed edit..
  29. Front end parts...
  30. TJ tube fenders
  31. single cab cummins. 12v or 24v
  32. GM 10 bolt 8.2 carrier for 3.08 and up/ 3.73 gears
  33. TJ rear upper control arms
  34. need rims!
  35. WTB 4.0 Head for a 97 ZJ
  36. 32-46 in plasma or lcd tv
  37. Pintle Hitch
  38. 2-Door 5-Speed Cherokee
  39. 4.0 explorer motor
  40. 82-95 Toyota 2wd automatic transmission
  41. wtt for 15x8 5 on 5.5 rims
  42. 231 transfer case
  43. trans for a 96 zj 4.0
  44. wtb 8 lugs 15x12 or wider chevy rims
  45. wtb or wtt i am looking for a cheap wheeler
  46. Jeep Cherokee lift shocks 4-6in
  47. engine hoist. rent, borrow,buy
  48. Argon tank
  49. looking for a SYE/CV driveshaft
  50. XJ 4.0l Flexplate
  51. WTT - 3" JK FT Lift for 2" OME
  52. soundbar and cd player wanted 95 yj
  53. tj windshield frame any shape don't need glass.
  54. tj drivers side windshield and door hinge.
  55. 700R4 to 231C Adapter
  56. 1979 Dodge Aspen parts
  57. WTB: XJ 93 Compatible Parts
  58. Pop up sunroof or glass
  59. U Bolt plates for a Corp. 14 bolt
  60. carb for Jeep 258
  61. WTB: Dune Toy
  62. Manik Grill Guard
  63. 700r4 inspection cover
  64. 39.5x18x16.5 bogger
  65. shock tabs
  66. Wheels and tires for a 96 GMC Sierra k1500
  67. Cummins Turbo or equivalent
  68. mud tires
  69. WTB Cooper Tire
  70. wtb 265/75/16's
  71. wtb- 35 or 36 x 12.5 x 15 tires (4 or 5)
  72. 92-97 F-250/350 diesel parts
  73. cj5 frame
  74. Mud tires...39.5" to 44"
  75. 80s chevy/gmc long box 4x4
  76. Ax 15 tranny with everything for it
  77. 00 xj window switch
  78. 30 or 31" tires All Terrain or Mud Tire
  79. cherokee bumper!!
  80. WTT my Mud terrain's for your A/t's *new pics*
  81. dodge 1500 axles or 4.10 gears
  82. 40 inch tires
  83. One 16x8 5on 5
  84. 4.56's for a 9"
  85. 15" ZJ rim
  86. steel
  87. A new puppy!
  88. 99 xj engine help
  89. wtb dodge door!
  90. 36-39" tires
  91. wtb yj windshield washer fluid tank
  92. dana 30 passenger side shaft
  93. Looking for a clean ZJfor sale around $2K
  94. Fiberglass topper for Dodge Ram
  95. Wanted 15" steel wheels for Jeep
  96. ***BF Goodrich KM1 tires (in good shape)***
  97. Need driver's door and hinges for 93 Grand Cherokee
  98. YJ Soft Top upper door Frames
  99. Looking for a set of 33x12.50x15's AT's or MT's
  100. bronco solid axle swap parts
  101. XJ np231 23spline
  102. Good running/driving jeep
  103. motor and trans 2000 gmc jimmy 4wd
  104. Need Help Getting Broken bolts out!!OR WTB yolks
  105. Dana 30 and AMC 20 Gears/Carriers
  106. WTB JEEP Canyon Wheels from a TJ
  107. 4.0 engine for 98 ZJ
  108. Need 2000 silverado parts!!!!!!
  109. 95 buick park avenue transmission
  110. 2.5 Exhaust Manifold Needed
  111. Dana 30 Axle
  112. dually rear end for ford
  113. working rear wiper motor for 88 wagoner
  114. '73-'80 GM 4x4 cab/'79-'87 GM fleetside shortbed
  115. '99 and newer jeep 4.0 intake manifold
  116. 15" wheels for a XJ
  117. 538 gears ford 9'
  118. r/c boat
  119. 80-96 TTB drop brackets-4" lift
  120. coil springs
  121. 2000 TJ 4.0 auto engine wiring harness
  122. 32-33" tires
  123. trans pan
  124. SBC small cap distributor.
  125. big ass tow hook
  126. 1980-2005 cruiser bike
  127. 8.8 Rear Axle
  128. steering wheel
  129. trade 2000 C5 corvette for 04+ Rubicon?
  130. 92-97 F-250/350 parts.
  131. 99-01 Longblock 4.0
  132. 14 bolt carrier
  133. sbc
  134. wanted duck decoys and layout boat
  135. D-44 axle shaft
  136. 16.5 8lug 8x6.5
  137. Looking for Truck
  138. Trail rig...wheeler...a toy for me and the lil man 1500ish
  139. Tj Front Drive Shaft
  140. 4l60e to np231 adpt
  141. axle sandblasted
  142. Need Misc. motor parts for xj 4.0 H.O.
  143. flow master 40 series
  144. dodge transfer case
  145. 14 bolt diff cover
  146. wtb dana 44 front for TJ
  147. looking for nice lifted xj/zj
  148. 96-97 Ford ZF S5-47 manual trans Diesel 4x4
  149. 33's MT for 15in wheels
  150. Deployed Soldiers Jeep!
  151. R&D Vehicles Wanted
  152. Spare Wheel
  153. WTB Cage for CJ7
  154. military tires
  155. Ford HP60 Stuff
  156. lots to trade for a nice trail rig prices added
  157. 2 Stock cherokee leafs & 2 stock wrangler leafs
  158. 96 and up explorer leaf packs
  159. WTT-my rims for TJ moab rims
  160. Yj 4.0 motor
  161. Small enclosed trailer
  162. TJ Soft top
  163. Buy or Trade 8" for 12" front springs for 73-87 Chevy / GMC
  164. 1-ton Cab & Chassis rear axle (63-64" WMS)
  165. Looking for older 3-6 person camper
  166. AX 15 out of 95+ xj
  167. 38" tires
  168. Tires
  169. radiator for xj 94
  170. 1.75x.120 dom
  171. figure 8/bump and run
  172. Transfer case for a 05 rubicon
  173. Looking for a 4.0 for my 97 cherokee
  174. 31x10.50r15 Mud terrains
  175. TJ to build
  176. 8 lug wheels 16x9 or 16x10
  177. i want a toyota 22re
  178. CJ leaf springs, STOCK
  179. Tj front driveshaft
  180. CJ Turbine wheels
  181. dana 70
  182. 94 up s10 short box (box)
  183. 1995+ Explorer
  184. dana 30 shafts
  185. small block ford parts
  186. Chevy Dana 44 Front Axle Caliper Bracket
  187. CJ bucket seat
  188. lookin for carpet for xj asap
  189. Grand cherokee 5.9 grill
  190. .40 ammo
  191. Yj Hard top rear window
  192. WJ doors
  193. Looking for Mud Tires
  194. Chevy passenger side flat top
  195. K5 Blazer Soft Top
  196. looking for old/used yj leaf springs
  197. manual transfer case for a ranger
  198. Aftermarket/Custom front bumper XJ
  199. 38.5"-41" tires for 17" rims
  200. 98 dodge dana 60
  201. need a dana 70 hd
  202. Stock JK Fender Flares
  203. original spare
  204. Dana 30 with 4.10s
  205. 32 10.50 15 super swamper radials
  206. sheetmetal
  207. 99 dodge ram wheels
  208. 93/97 Ford Ranger 4x4 Parts Wanted
  209. 231j transfer case
  210. wanted tow truck or wreckers..ford , international
  211. WANTED ZJ front sway bar......Paying cash
  212. Looking for a set of tube fenders for a yj
  213. Pyrometer Guage
  214. edelbrock performer for a 460
  215. sbc ceramic coated headers for trade?
  216. Two 40 Inch Tires
  217. Machinist tool box/ Machinist tools
  218. enduro motorcycle
  219. Tj grille/ tailgate.
  220. 2000 XJ brush guard
  221. welding table
  222. 15x10-8 bolt wheels
  223. 241 case
  224. Xj roof rack
  225. Wanted: TJ spare tire extension
  226. Wtb chevy truck w'bad motor
  227. WTT Colt AR for dirt bike
  228. Service box or flatbed for small pickup/S10
  229. 244/75/16 Tires-Jeep Wrangler
  230. Jeep wiring harness wanted
  231. 4 barrel intake 302 winsor
  232. need a shortbox
  233. gauge cluster
  234. need S-10 231 T-case
  235. 16x10 WHEELS
  236. 35 inch tires for 20 inch rims
  237. 35 or 36 inch tires for 16inch rims
  238. toyota steering knuckle
  239. F150 351W Motor
  240. Speedo input for an 89 yj
  241. NSFW! Sway bar: 1973- 86 GM 2WD Truck. NSFW!
  242. D44/9in gears
  243. 97' F-350 Dash Pad Gray
  244. TRADE: 315/70/17 MT's for 285 or 315 AT's
  245. 1345 manual tcase ( fixed frt. & rr. )
  246. 1- 5 on 4 3/4 rim
  247. Jeep Tj door hinges, windshild hinges, mirrors, light mounts
  248. Axle truss for a 60
  249. Ford 302 WANTED
  250. Looking for a yj computer
