  1. wtt-bike for truck
  2. Looking for a set of for early bronco axles
  3. ZJ Lights.
  4. ZR2 lift etc...
  5. 2000 superduty suspension lift wanted
  6. dana 30 long arm
  7. dana 60
  8. need 31s or 33s asap. 400 at most
  9. wagon wheels 5 on 4.5 or other jeep rims
  10. ford truck passenger side sun visor
  11. adapter
  12. zj long arms or parts
  13. Wanted: 5x4.5 wheels to use as rollers, two needed
  14. TJ Rear Seat Belts
  15. 99-04 grand cherokee 4.0 engine...
  16. WTB Rear Driveshaft - 89 2.3l 4x4 5spd
  17. 17" 5x5.5 rim
  18. rocker guards and corner guards.
  19. High stear for a GM 60
  20. 2000+ r1 can be wrecked whatever
  21. Drivers side door panel 1998 - on sonoma / s-10
  22. WTB: .380 ruger lcp or .380 S&W bodyguard
  23. need super duty t case asap
  24. CJ 7 Frame
  25. trans wanted
  26. Stainless Steel kitchen sink
  27. 38-39.5" tire for 17" rim
  28. looking for xj 4.5 or 5.5 inch coil springs
  29. WTB Jeep 4.0 Engine
  30. 4.0L Thermostat Housing
  31. 33s or 35s
  32. looking for a quad---four wheeler or three wheeler
  33. CJ radiator grille support strut rods
  34. Need a 2.5 L motor for a 1999 Wrangler.
  35. WJ Overland Rock Rails
  36. TJ Fenders
  37. C6
  38. XJ control arm drop brackets
  39. ford 9"
  40. Couple axles wanted
  41. 78-79' Bronco roll bar/cage
  42. Trade??
  43. Body lift blocks
  44. 20" Ford Rims
  45. Trucks wanted
  46. i need some tubing bent in kalamazoo
  47. Rat rod
  48. WTT 31x10.5x15
  49. wtb ex cab short bed 5 speed cummins
  50. diesel parts, list posted
  51. wanted tj radiator
  52. Verizon Blackberry
  53. Looking for a Blazer
  54. cj or yj grey back seat / back shoulder belts
  55. tires for 15 inch rim 33,32s $150 31 if mud t..
  56. Super Duty parts
  57. WTB chevy s10 grill swap(94-03)
  58. ranger tail gate
  59. Superflex Joint Tool
  60. Front axle for 2000 F250 4x4 with 3.73s
  61. drivetrain
  62. '89 YJ Passenger Fender
  63. 6 " steel pulley
  64. 1
  65. 31s or 32s
  66. Would like exhaust welded in Ann Arbor area
  67. Wanted misc. Items, highjack, steering wheel,
  68. TJ rear uppers
  69. WTT 33" tires for 35's
  70. e4od for 7.3L **any condition, prefer UNREBUILDABLE damage**
  71. Wanted: Wheels, Tires, Coupons, Giftcards, tube bender
  72. Ground Hawgs
  73. wanted- someone to machine small parts
  74. dodge diesel 5 speed
  75. wtb: good running lower mileage 4.0
  76. Bunch of XJ parts needed - some stock - some aftermarket
  77. Suburban interior that will fit 98'
  78. axle shaft for k5 blazer
  79. 94 - 96 e4od to fit 91 bronco
  80. Teraflex 4 to 1 low for np231
  81. needs transportation
  82. Grand cherokee axle
  83. Ford 8.8 w/ 4.10's
  84. Looking to buy a jeep $2500
  85. military tent
  86. 85 toyota parts
  87. 1/2 Door panels
  88. heater box for 1986 ford pickup
  89. need a 4.0 head for a 99 cherokee
  90. Locking Mechanism
  91. 4l60e/4l80e need one today
  92. looking for a transfer case to hook up to a 92 xj 4 speed
  93. EFI pump to Carb Fuel pressure regulator
  94. wtb decent priced laptop
  95. parts washer
  96. Wanted Toyota Truck/4Runner 84-89
  97. Need nerf bars for a TJ
  98. Ranger or Bronco II "scrap or project" Vehicle
  99. WTB: pre96 ECM
  100. Dependable 4x4
  101. 02-08 dodge ram front license plate bracket
  102. 02-08 dodge ram oem foglights
  103. 02-11 dodge ram 1500 rear oem hitch
  104. Ford axles
  105. Wanted wagoneer front springs
  106. 231 t-case adapter for a t-350 trans
  107. small to medium size pontoon boat
  108. WTB: 30x9.5-15
  109. WTT welder for
  110. looking for 44 front axle for tj
  111. samurai transfer case, cherokee leafs
  112. ZJ Front Axle needed ASAP
  113. i need a 4.0
  114. 91 f 350 7.5 (460) parts
  115. Early Bronco axles
  116. WTB: 4 - 33"X12.5" BFG M/T KM1s
  117. ecotech 2.2l engine vin f GM
  118. tires
  119. WTB 5 on 4.5 xj wheels
  120. vortec 350 heads
  121. wtt for an xj
  122. Tires 31" or smaller
  123. AWD Jimmy Front Axle
  124. ranger/b2 hood
  125. 4.0L Jeep 97-98
  126. Need honda crx parts
  127. need gun repair
  128. WTT:32X11.50X15 Super Swampers TSL with Fake beadlock rims 5x4.5
  129. rpm gauge and cb stuff
  130. Cherokee
  131. 33 inch or bigger tires on dodge rims
  132. qoute for sandblasting rims
  133. cj7 front fender
  134. 97 Ford Door panel
  135. sandblasting on west side
  136. decent window tint guy
  137. CB Tuning
  138. dana 30 long arms
  139. looking for a new not used mega short sye for a 98' wrangler
  140. WANTED: Holley 470 Truck Avenger
  141. wtb 97-04 f150 lift
  142. WTB: Dana 60 lockouts
  143. I need a on the side body man "2003 tahoe"
  144. I need a on the side body man "2003 tahoe"
  145. Dana 44 or 60 front
  146. looking for a jeep scrambler
  147. WTB: Ford 9in w/ 4.11 gears
  148. TJ for $5000
  149. wanted 4.7 engine
  150. Salvage Yards list your 8.8!!!!
  151. Bench seat for bronco
  152. i need a truck bad cash in hand
  153. 83 cj 7 front springs
  154. 90-96 Ford f-150/bronco power window motors
  155. Gas Saver Car
  156. wtb a ford dana 60 kingpin crossover kit or pieces
  157. 3" spark aresstors
  158. stock tj front bumper
  159. tj 2.5 ,231,ax5
  160. wtb items for a cj7
  161. project 68 69 70 dodge charger
  162. need 8.8 for 95 ford bronco
  163. WTB: 2wd s10/camaro/trans am....tims/tires
  164. wtb: dakota/durango brush guard
  165. WTB: 35's - can be worn out
  166. 33-35 trxus STS
  167. oil dip stick tube
  168. 2 8 lug rollers near northwest indiana
  169. Ford D44 internal lockouts
  170. Ford D44 19 spline internal lockouts
  171. toyota power steering boxes
  172. 241 transfer case
  173. need a 93 wrangler core trans
  174. at&t phone
  175. need 1 18-39.5-15
  176. 6 to 8in lift
  177. TJ Windshield Frame
  178. 3.42 gears for 3/4 ton Chevy
  179. Load Range E tires
  180. 14bolt FF Lower michigan
  181. Jimmy glass
  182. 4R100 rebuildable core, 7.3
  183. Wrangler seats
  184. Pitbull Rockers
  185. waggy leafs & xj leafs
  186. WANTED: JK tires or tires/wheels
  187. Lightweight wheels
  188. LOOKING FOR A PCM FOR A 93 Grand Cherokee with 5.2
  189. AMC Th400 needed
  190. NEEDED 4.2 Valve Cover
  191. s10 or blazer zr2 wanted
  192. 31's
  193. looking for a used f150 super crew cap
  194. XJ tube/safaro doors
  195. h1 bead lock inserts
  196. high pinion ford dana 44
  197. misc xj/cherokee parts
  198. a car
  199. Roof rack for 91-98 Suburban
  200. Looking for hitch for 1996 F250
  201. Wanted 31x10.50R15 tires
  202. honda 11hp or 13hp
  203. set of 37-40 tires. 16 or 16.5 wheel size.
  204. 02-11 dodge ram 6' bed soft tonneau cover
  205. jeep commander rim and tire
  206. WTT 33/12.5/15 Nitto Terra Grapplers
  207. hood spring
  208. WTB: Ford 5r55e trans
  209. Alignment rack
  210. ? stub shaft
  211. stall
  212. wtb 39.5s or bigger mud tires
  213. wtt xj adjustable lower control arms for uppers
  214. WTB: 2004-2006 Jeep Rubicon
  215. yj transmission
  216. wtb: garage fridge
  217. dana 35 ttb
  218. 90 toyota transmission
  219. 38-42 inch mud tire
  220. 12 valve cummins
  221. wtb tires and Dual Exhaust for dodge ram
  222. fishing stuff
  223. 5*4.5 8 inch wide wheels
  224. 31x10.5*15 MTR
  225. cheap garage door opener
  226. tj tailgate
  227. brake master cylinder for 89 wrangler
  228. 16.5 5x5.5 wheels
  229. XJ Manual, Black Breakaway Mirrors...
  230. Ford ranger PARTS TRUCK
  231. gears for dana 44s
  232. Rear crush corners
  233. need a tire
  234. wtb: s-10 brush gard (2000)
  235. cheap 4.0
  236. Cj7 fan shroud
  237. cherokee 4.10 or 4.56
  238. A good Jeep frame
  239. Winch (9000#ish)
  240. I need a recliner.
  241. stock xj front bumper
  242. 98 TJ Driver Side Front Fender
  243. jeep honcho
  244. WTB: stock TJ front and rear bumpers
  245. need rear seat for tj
  246. 8.8 bolt it wanted for yj
  247. 00-01 xj front exhaust pipe
  248. stock jeep rims and tires
  249. WTB Dana 30 3.73 and Up Carrier for XJ
  250. WTB Powertrax for Dana 30
